Problem Trunking Between Router and Switches
iftam0001
I am experiencing some really odd behavior when I add another VLAN to the switch, and I am hoping someone can tell me if I am doing anything wrong or what may cause this problem. Here's the topology on how the router and switches connected and everything is on VLAN 1.
Router - Cisco 1921
Switch A - Cisco 3560-24PS
Switch B - Cisco 3560-24PS
Switch A port configuration and show output:
The router is connected to int fa0/1 of switch A.
interface FastEthernet0/1
 description Router
 switchport mode trunk
Switch A is connected to Switch B via interface gi0/1.
interface GigabitEthernet0/1
Switch A#sh int gi0/1 trunk
Port        Mode         Encapsulation  Status        Native vlan
Gi0/1       on           802.1q         trunking      1
Port        Vlans allowed on trunk
Gi0/1       1-4094
Port        Vlans allowed and active in management domain
Gi0/1       1,10
Port        Vlans in spanning tree forwarding state and not pruned
Gi0/1       1,10
Switch A#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/2, Fa0/3, Fa0/4, Fa0/5, Fa0/6, Fa0/7
                                                Fa0/8, Fa0/9, Fa0/10, Fa0/11, Fa0/12
                                                Fa0/13, Fa0/14, Fa0/15, Fa0/16, Fa0/17
                                                Fa0/18, Fa0/19, Fa0/20, Fa0/21, Fa0/22
                                                Fa0/23, Gi0/2
10   Guest_Wireless                   active
SwitchA#sh int status
Port      Name               Status       Vlan       Duplex  Speed Type
Fa0/1     Router     connected    trunk      a-full  a-100 10/100BaseTX
Gi0/1                        connected    trunk      a-full a-1000 1000BaseSX SFP
Switch B port configuration and show output:
Switch B is connected to Switch A via interface gi0/1.
VLAN configurations:
interface Vlan1
 ip address 10.1.1.10 255.255.255.0
interface Vlan10
 ip address 10.2.1.10 255.255.255.0
Switch B#sh int gi0/1 trunk
Gi0/1       1-4094
Gi0/1       1,10
Gi0/1       1,10
Switch B#sh vlan
1    default                          active    Fa0/1, Fa0/2, Fa0/3, Fa0/4, Fa0/5, Fa0/6
                                                Fa0/7, Fa0/8, Fa0/9, Fa0/10, Fa0/11
                                                Fa0/12, Fa0/13, Fa0/14, Fa0/15, Fa0/16
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20, Fa0/21
                                                Gi0/2
Port configuration of ASA on VLAN 10:
interface FastEthernet0/23
 description ASA
 mls qos trust cos
 macro description cisco-router
 spanning-tree portfast trunk
 spanning-tree bpduguard enable
SwitchB#sh int fa0/23 trunk
Fa0/23      on           802.1q         trunking      1
Fa0/23      1-4094
Fa0/23      1,10
Fa0/23      1,10
SwitchB#sh int status
Fa0/23    ASA         connected    trunk      a-full  a-100 10/100BaseTX
From switch B:
I can ping vlan 10 IP of 10.2.1.10 and the ASA 10.2.1.254
From switch A:
I can ping vlan 10 IP of 10.2.1.10 but cannot ping the ASA IP 10.2.1.254
From router:
I cannot ping vlan 10 IP of 10.2.1.10 and the ASA IP 10.2.1.254
I don't understand why I cannot ping VLAN 10 from the router even though I trunked the port, and definitely don't know why I can ping VLAN gateway IP but not the device on VLAN 10. I even move the interface VLAN configuration from switch A to switch B, but still getting the same results. Any help regarding this issue will be greatly appreciated.
Tony Daniels
Your setup is a bit confusing. You first show a router and two switches, then you have an ASA listed.
Then the ASA has a port of F0/23 which is unusual.
The ASA is in VLAN 10, it's just another device on VLAN 10 besides the gateway. The ASA is connected to port fa0/23 in switch B.
Sorry about the confusing setup, like it or not, I inherited this setup and can't change it at the moment.
If I am understanding your topology correctly, you will not be able to ping from the router because your attempting to ping vlan 10, but the router only knows about vlan 1. This won't work.
When you introduce two vlans to the switches, then the router needs to understand this also. This is where subinterfaces come into play.
Router Setup: (Assuming Router is connected to switch using F0/1)
Vlan 1:
interface FastEthernet0/1.1
  ip address (vlan 1 IP address)
   encapsulation dot1q 1 native
interface FastEthernet0/1.10
   ip address (vlan 10 IP address)
   encapsulation dot1q 10
Now the router can participate in the vlan config. You would remove the IP address from the F0/1 interface and move it to the sub-interface.
Make sense?
This is called "router on a stick" configuration. Here is a link to help explain:
http://www.orbit-computer-solutions.com/How-to-Configure-Router-on-a-Stick-InterVLAN-Routing.php
