Problem with 3560g switch
desai.raj34
Community Member
Dear all,
When i connect my switch to hyperterminal using console cable, switch boots perfectly but i cant see the prompt. Instead of that i am getting below:
%LINEPROTO - 5-UPDOWN : Line protocol on Interface Vlan1. Changed state to down
%SPANTREE- 5 - EXTENDED_SYSID Extended SysID enabled for type VLan
%SYS-5-RESTART : System Restarted
Sandeep Choudhary
Hi Raj,
just reset the switch :
Physically opened the switch,
- Hold the mode button  (directly on the mini board) and reboot the unit – Release it when the light on top 1x went off
- Accept the message to reset to factory default
- type boot and voila problem fixed.
may be it helps.
Please rate if it helps.
