problem with ASA redistributing VPN statics
jack.leung
Hi all,
I'm trying to redistribute the statics the ASA injects using reverse-routing and its not doing it. It will redistribute static routes I add in there but not the ones injected via RRI. Here is the config I am using.
ip local pool VPNPool172.20.11.129-172.20.11.254 mask 255.255.255.128
access-list STATIC-ACL standard permit 172.20.11.128 255.255.255.128
route-map STATIC-RM permit 10
match ip address STATIC-ACL
router eigrp 1
  redistribute static route-map STATIC-RM
crypto map outside_map 30 match address outside_1_cryptomap_1
crypto map outside_map 30 set reverse-route
doing a show access-list STATIC-ACL shows no hits. If I add a static route manually myself it redistributes fine. Am I missing something here? The ASA I have is a 5510 running 8.2.1
6 Replies 6
You're saying that if you manually configure a static route on the ASA, it gets redistributed via EIGRP to the inside?
When you do a ''sh route'' on the ASA do you see the static VPN routes?
Federico.
HI Federico,
Correct I am trying to redistribute the statics on the ASA into EIGRP. And yes I do see the static routes on the ASA (even the VPN ones). However only the statics I manually configure are redistributed. The ones that are injected from RRI does not.
As a test what if you redistribute without a route-map...
Instead of:
router eigrp 1
Have:
router eigrp 1
  redistribute static
Does it make any difference?
Federico.
Yes, the first thing I tried and no difference.
Funny thing is that the documentation talks about RIP and OSPF but not EIGRP:
Reverse Route Injection (RRI) is used to populate  the routing table of an internal router that runs Open Shortest Path  First (OSPF) protocol or Routing Information Protocol (RIP) for remote  VPN Clients or LAN²LAN sessions.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00809d07de.shtml
I am sure it should work for EIGRP also (version 8.x)....
Federico.
I have found exactly the same issue today on version 8.2 code.  We can redistribute configured static routes into EIGRP without issue.  The RRI static routes however will not redistribute correctly regardless of the method of redistribution.
I have checked the bug database and cannot locate a matching entry.
