Problem with back-to-back frame relay
rakyomin78
Serial0/0/1 is down, line protocol is down
  Hardware is GT96K Serial in async mode
  Description: ** MODBUS data From BR-A **
  MTU 1500 bytes, BW 9 Kbit, DLY 100000 usec,
  Encapsulation SLIP, loopback not set
  DTR is pulsed for 5 seconds on reset
  Last input never, output never, output hang never
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 6 kilobits/sec
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=upThe interface config of the router:
router1#show run | s int
crypto pki trustpoint TP-self-signed-
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-
revocation-check none
rsakeypair TP-self-signed-
interface FastEthernet0/0
  ip address 10.10.10.1 255.255.255.0
duplex full
speed auto
no keepalive
no mop enabled
interface FastEthernet0/1
ip address 10.10.1.1 255.255.255.0
duplex full
speed auto
no mop enabled
interface Serial0/0/0
bandwidth 64
no ip address
encapsulation frame-relay
load-interval 30
no keepalive
serial restart-delay 0
frame-relay traffic-shaping
frame-relay ip rtp header-compression
max-reserved-bandwidth 100
interface Serial0/0/0.300 point-to-point
description *** PVC to Back bone router A ***
bandwidth 64
ip address 192.168.10.10 255.255.255.252
frame-relay interface-dlci 300 CISCO
  class BRA
interface Serial0/0/1
physical-layer async
description ** MODBUS data From backbone router A **
no ip address
load-interval 30
keepalive 10
The router's se0/0/1 shows down down, but it has light, the remote router's se0/0/1 is up up status. the local router and remote router are connected via vsat using frame relay, it seems to be physical issue but there's light on the serial interface.
Peter Paluch
I am somewhat at loss in your description. You are commenting that the S0/0/1 is reported as down/down - but the Frame Relay is configured on the S0/0/0 interface whose state is not mentioned by you. In addition, the S0/0/1 is configured for asynchronous mode - I am not saying this is an error but such a setting is used mostly with legacy modems so please verify if that setting is appropriate.
Can you clarify this please for us? Thank you!
Best regards,
Peter
Peter Paluch
Best regards,
Peter
