Problem with C3524 XL-EN Switch
erick021972
What causes this problem?
C3500XL POST FAILURE: MII Test: Failed
C3500XL POST FAILURE: Ethernet Controller Test: Failed
This seems to be a Hardware issue.
Thank you.
Hi Erick,
Can't really diagnoss the reason behind this, but for sure as poined in the earlier post this is a hardware failure and probably you'll have to get the switch replaced, because usually these are not recoverable failure.
-> Sushil
Thank you
