problem with cisco 2511
mohammed hashim
hi all
I am using cisco 2511 to telnet to other devices.
the problem is after one or two hours, I loss the connection with the devices and I have to reload the Access Server, then it gets work.
this is the running config of the Access Server (cisco 2511)
AS2511#show run
Building configuration...
Current configuration : 990 bytes
version 12.2
hostname AS2511
logging queue-limit 100
enable password cisco
ip subnet-zero
ip host SWITCH-1 2013 172.22.1.1
ip host SW4 2012 172.22.1.1
ip host SW3 2011 172.22.1.1
ip host SW2 2010 172.22.1.1
ip host SW1 2009 172.22.1.1
ip host R1 2001 172.22.1.1
ip host R2 2002 172.22.1.1
ip host R3 2003 172.22.1.1
ip host R4 2004 172.22.1.1
ip host R5 2005 172.22.1.1
ip host R6 2006 172.22.1.1
interface Loopback0
no ip address
interface Ethernet0
ip address 172.22.1.1 255.255.0.0
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
no ip http server
ip classless
line con 0
password cisco
login
line 1 16
exec-timeout 0 0
flush-at-activation
login
no exec
transport input all
transport output telnet
line aux 0
line vty 0 4
password cisco
login
transport input pad v120 telnet rlogin udptn
end
AS2511#
any thing can solve this problem
thanks,
Reza Sharifi
Can you try a couple of things and test again
1-Usually it is recommended to use the loopback address for all the devices.  So, can you create a loopback interface and assign an IP address to it and change the host to that address?
Example:
ip host SWITCH-1 2013 1.1.1.1
where 1.1.1.1 is ip address of the loopback address.
and so on......
2-Under line 1 16 can you remove
flush-at-activation
login
and test again?
