Problem with Cisco 2801 router
vladimir-simic
I can connect to the Cisco 2801 with console cable and this is the log file
ERROR: could not add peer
mbox - no peer found with tag = 20024ERROR: could not set preference
ERROR: could not set peer info
mbox - no peer found with tag = 20025ERROR: could not set preference
mbox - no peer found with tag = 20026ERROR: could not set preference
mbox - no peer found with tag = 20027ERROR: could not set preference
mbox - no peer found with tag = 20028ERROR: could not set preference
mbox - no peer found with tag = 20029ERROR: could not set preference
mbox - no peer found with tag = 20030ERROR: could not set preference
mbox - no peer found with tag = 20031ERROR: could not set preference
mbox - no peer found with tag = 20032ERROR: could not set preference
mbox - no peer found with tag = 20033ERROR: could not set preference
What's the problem with my router?
InayathUlla Sharieff
Try to brk into rommon and upgrade the firmware. If you still see the same issue after upgrading it log a case with TAC and replace the device.
Inayath
