Problem with Cisco 4507R
Trung Minh
Dear Experts,
My switch running is normal but suddenly it has problem with red light(Output fail) as attached file.
I also try reboot but seem to switch can not
There is output while switch reboot:
* Welcome to Rom Monitor for WS-X45-SUP6-E System.      *
* Copyright (c) 2003-2009 by Cisco Systems, Inc.         *
* All rights reserved.                                   *
Flash die # 0: Intel 33554432Bytes
Flash die # 1: Intel 33554432Bytes
Flash die # 2: Intel 33554432Bytes
Flash die # 3: Intel 33554432Bytes
Determining FTL format status of volume.
Volume is FTL formatted.
Checking the partition table and boot sector...
Checking FAT, Files and Directories...
Reclaiming unused space...
Updating FAT...
Rom Monitor Program Version 12.2(44r)SG5
CPU Rev: 2.1, Board Rev: 6, Board Type: 10, CPLD Jawa Rev: 18
Chassis: WS-C4507R-E
Front Panel Phy is Bcm5482s
Got Mac Address: 00:25:84:1e:33:bc
MAC Address  : 00-25-84-1e-33-bc
Ip Address   : Not set.
Netmask      : Not set.
Gateway      : Not set.
TftpServer   : Not set.
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
******** The system will autoboot now ********
config-register = 0x2101
Autobooting using the first file from bootflash.....
Rommon reg: 0x00004380
Reset2Reg: 0x00000FFF
Darkside controller 0x0B394EBC..0x0B3A326E original size:0x00012092#
Tatooine controller 0x0B3A326F..0x0B40C25B original size:0x00094F89##
Forerunner controller 0x0B40C25C..0x0B4D1EA8 original size:0x001D0F9C
diagsk5 version 3.2_a
prod: WS-X45-SUP6-E part: 73-10597-12 serial: JAE14190WMV
Power-on-self-test for Module 3: WS-X45-SUP6-E
Test Status: (. = Pass, F = Fail, U = Untested)
CPU Subsystem Tests ...
seeprom: Pass
Traffic: L3 Looopback ...
Test Results: Pass
Traffic: L2 Loopback ...
Test Results: Pass
Switching Subsystem Memory ...
Packet Memory Test Results: Pass
Module 3 Passed
Exiting to ios...
Rommon reg: 0x00000380
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASE-M), Version 12.2(50)SG3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 07-Jul-09 20:28 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x1222AE9C
Any help are appreciated
Thanks & Regards,
7 Replies 7
Leo Laohoo
I am suspecting the extraction fan is running low RPM or is blocked.
Power off one of the PS (not the entire chassis), wait for 5 seconds and power it back on.
Make sure both PS do not sound like loud squeeking or squeeling sound.
Thank you for feedback.
I already tried power up one of each time, but still problem.
Before this time, i did not change any on this chassis.
Any one please help?
See this:
Table A-8     1400 W AC-Input Power Supply LEDs
LED
Meaning
INPUT OK
Green—Source AC voltage is OK. (Input voltage is 85 VAC or greater.)
Off—Source AC voltage falls below 70 VAC, is not present, or the power supply is turned off.
FAN OK
Green—Power supply fan is operating properly.
Off—Power supply fan failure is detected.
OUTPUT FAIL
Red—Problem with one or more of the DC-output voltages of the power supply is detected.
Off—DC-output voltage with acceptable margins.
Note For proper operation of the OUTPUT FAIL LED, systems with single power supplies must be configured with a minimum of one fan tray assembly and one supervisor engine. Systems with dual power supplies must have a minimum configuration of one fan tray assembly, one supervisor engine, and one additional module. Failure to meet these minimum configuration requirements can cause a false power supply output fail signal.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/catalyst4500e/installation/guide/0aspecs.html#wp1047656
Hope it helps.
forticis
How did you fix this problem.?
In my case, the fans on left chassis is very dusty. I shutdown the Switch and cleaned the fans after that all status is fine.
You also should see the status of all light where is the light warning then focus that problem.
Hope this can help you.
4507R+E both PS are showing "output fail" and switch stops working. (Switch photo attached).
Powering OFF and ON both the power supplies fixes the probem for few days.
After powering off and on, PS and FAN status shows ok
This problem has repeated twice now.
------------------ show power detail ------------------
Power                                             Fan      Inline
Supply  Model No          Type       Status       Sensor   Status
PS1     PWR-C45-4200ACV   AC 4200W   good         good     good
PS1-1                         220V   good
PS1-2                         220V   good
PS2     PWR-C45-4200ACV   AC 4200W   good         good     good
PS2-1                         220V   good
PS2-2                         220V   good
Power supplies needed by system    : 1
Power supplies currently available : 2
Power Summary                      Maximum
 (in Watts)              Used     Available
System Power (12V)        808        1360
Inline Power (-50V)         0        3352
Backplane Power (3.3V)     40          40
Total                     848 (not to exceed Total Maximum Available = 4200)
Regards,.
