Problem with Cisco Catalyst
chaimukcung
Hi, I got this error frequently in my Cisco Catalyst 3750 (occurred in several ports) and did not understand what to do.
Description: Interface GigabitEthernet1/0/19, changed state to up
Explanation: The interface hardware went either up or down.
Recommended Action: If the state change was unexpected, confirm the configuration settings\n\ for the interface.
Type: LINK-3-UPDOWN
We have several VLAN configured on it.
Please advice.
Acung
5 Replies 5
Amit Singh
Acung,
This simply means that your interface has gone up/down i,e fluctuating. This could happen due to interface configuration or loose cable connetcivity on the port.
What is connected at the other end. Do you loose conenctivity. Please paste the switch config.
-amit singh
One of them (error port) not connected to anywhere, the other connected to to the computer via patch panel. Nope, the connection is good.
Here is the configuration :
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service sequence-numbers
hostname GMSI-SW01
enable secret xxx
no aaa new-model
clock timezone UTC 8
switch 1 provision ws-c3750g-24ts
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
description management interface
interface GigabitEthernet1/0/2
description server interface
switchport access vlan 2
switchport mode access
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
description development
switchport access vlan 6
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
description data_lt3
switchport access vlan 3
switchport mode trunk
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
description data_lt2
switchport access vlan 4
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
description data_lt1
switchport access vlan 5
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
ip address 192.168.128.1 255.255.255.0
interface Vlan2
ip address 192.168.129.1 255.255.255.0
ip helper-address 192.168.129.11
ip helper-address 192.168.129.12
interface Vlan3
ip address 192.168.130.1 255.255.255.0
ip helper-address 192.168.130.11
interface Vlan4
ip address 192.168.131.1 255.255.255.0
interface Vlan5
ip address 192.168.132.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.129.10
ip http server
snmp-server community xxxxx RO
control-plane
ntp clock-period 36029249
ntp server 192.168.129.11 key 0 prefer
end
Please advice.
Acung
Acung,
Why you have configured the switch ports as access to vlan 5 and also the trunk port.
Please remove the access vlan config from the trunk ports. Configure the ports as following:
Please see the link below for managing the NIC issues :
http://www.cisco.com/warp/public/473/46.html#maintain
HTH,Please rate if it does.
-amit singh
It's configured that way because that port connected to other switch (previously) and now connected to the computer directly.
That's the reason why the error logged?
How about port 4 & 8 ? The error logged for those ports as well.
Please advice.
Acung
