Privilege Level command
Anand Narayana
Level 6
Level 6
this is my working configuration in my Cisco 1751 router, with this i can directly login to the router with full access to it, without accessing for "enable password", ie.
username: anand
password: xxxx
1751#
username anand privilege 15 password xxxx
privilege exec level 15 configure terminal
line vty 0 4
privilege level 15
the same kind of thing i wanted to configure in my Pix/ASA, can you help me out in this.also i wanted a privliged level 1 user should not a enter in to "enable" mode, the "enable" command should get denied.
royalblues
Level 10
Level 10
anand,
I don think you can directly telnet/ssh with a privilege level 15 to a pix or the asa.
You always enter the user mode even when you are using ACS with shell authorization
Narayan
royalblues
Level 10
Level 10
anand,
Narayan
Thanks Narayan. infact b4 posting this, i went & searched documents related to this, but couldn't succeed, that is why thought of post in this, any thanks once again.
