Problem with EIGRG doesn´t work
blisteink4m
Visitor
Hello I am trying to use EIGRP on Packet Tracert but i don´t get, this is my topology
These are the config files
R1
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname R1
enable password 7 0822455D0A16
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524JHHA
no ip domain-lookup
spanning-tree mode pvst
interface Loopback0
 ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
 shutdown
interface GigabitEthernet0/1
 ip address 192.168.10.1 255.255.255.0
 duplex auto
 speed auto
interface Serial0/0/0
 ip address 10.1.1.2 255.255.255.252
 clock rate 128000
interface Serial0/0/1
 no ip address
 clock rate 2000000
 shutdown
interface Vlan1
 no ip address
 shutdown
router eigrp 10
 network 192.168.20.0
 network 10.1.1.0 0.0.0.3
 network 192.168.10.0
ip classless
ip flow-export version 9
banner motd
acceso restringido
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
 transport input telnet
line vty 5 15
 login
end
ISP
version 15.1
hostname ISP
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX15248ZCZ
no ip domain-lookup
 no ip address
 duplex auto
 speed auto
 shutdown
 no ip address
 duplex auto
 speed auto
 shutdown
 ip address 10.2.2.2 255.255.255.252
 clock rate 128000
interface Vlan1
 no ip address
 shutdown
router eigrp 10
 network 10.2.2.0 0.0.0.3
 network 209.165.200.0 0.0.0.31
ip classless
no cdp run
banner motd
banner motd
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
line vty 5 15
 login
end
R3
version 15.1
hostname R3
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX152474D8
no ip domain-lookup
interface Loopback0
 ip address 192.168.40.1 255.255.255.0
 no ip address
 duplex auto
 speed auto
 shutdown
 ip address 192.168.30.1 255.255.255.0
 duplex auto
 speed auto
 no ip address
 clock rate 2000000
 shutdown
 ip address 10.2.2.1 255.255.255.252
interface Vlan1
 no ip address
 shutdown
router eigrp 10
 network 192.168.30.0
 network 192.168.40.0
 10.2.2.1 0.0.0.3
ip classless
banner motd
acceso restringido
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
line vty 5 15
 login
end
I check the file but i dont´t find any error, when I execute show ip route eigrp I haven´t any route to remote router with EIGRP protocols
5 Replies 5
burleyman
Level 11
Level 11
Double check all you interface IP configurations and you will see the issue. I can give you the answer but if you are studying it will help for you to track it down.
There are also some errors in the EIGRP config as well but start with the interfaces.
Mike
ISP router looks to be missing 10 range back to R1 in eigrp process , also the public ip address is being advertised in R3 would have thought that would be the ISP router itself
add to ISP router
is this correct in R3
also you have loopbacks advertised in ISP eigrp that are not actually there but would belong in r1 and r3 to be advertised
As Mike has said there in his post check the interfaces that are in the devices and also whats actually being advertised on the eigrp process locally for that device , each interface should have a corresponding advertisement
Predrag Jovic
Level 8
Level 8
R1
ISP
Overlapping IP addresses
This should work.
ISP
int s0/0/0
description Link to R1
no shut
int s0/0/1
description Link to R3
router eigrp 10
R1
int s0/0/0
description Link to ISP
ip address 10.1.1.1 255.255.255.252
no shut
int gi0/1
description Link to Switch 1
no shut
int loopback 0
router eigrp 10
network 192.168.10.0 0.0.0.255
network 192.168.20.0 0.0.0.255
R3
192.168.20.
int ser0/0/1
no shut
int gi0/1
description Link to Switch 3
no shut
int loopback 0
router eigrp 10
network 192.168.30.0 0.0.0.255
network 192.168.40.0 0.0.0.255
This was in your config on the ISP router but it is not on the drawing.
Mike
