08-12-2014 11:26 AM - edited 03-07-2019 08:22 PM
I am having problems getting DHCP across a 3570 switch.
The network that I need DHCP for is: 192.168.6.0 (VLAN 2)
DHCP Server: 192.168.6.2 (VMWare; vswitch configured as VLAN 2)
| connected to 2960
interface GigabitEthernet1/0/31
switchport mode trunk
switchport nonegotiate
spanning-tree portfast trunk
| 2960 to 3750 trunk port
interface GigabitEthernet1/0/1
description Trunk (3750X)
| 3750 trunk port
interface GigabitEthernet1/0/4
description Trunk (VM Rack)
mls qos trust dscp
| 3750 to 2960 LAN switch
interface GigabitEthernet1/0/12
description P1 LAN
switchport trunk native vlan 2
mls qos trust dscp
| 2960 trunk port
All other ports on the P1 LAN 2960 are configured the same:
interface GigabitEthernet1/0/x
description P1 LAN
switchport access vlan 2
switchport mode access
The VTP server is the 3750:
interface Vlan2
ip address 192.168.6.1 255.255.255.0
ip helper-address 192.168.6.2
I can connect a PC with a static IP to the P1 LAN switch and that works, but I cannot get a DHCP assignment.
Any suggestions would be appreciated.
Thanks >> Joe
08-12-2014 11:48 AM
Hey Joe,
From this topology, I believe you have interface vlan 2 either on 2960 or 3750 (VTP server), so can you ping the 192.168.6.2 from that switch alternatively i want you to check the connectivity between DHCP server and relay agent.
HTH.
Regards.
RS.
08-12-2014 02:34 PM
Yes, you are correct.
The 3750 is the VTP Server with the VLAN configs.
I can Ping from the DHCP server all the way across to a PC on the 2960 being used for the P1 LAN. The PC also works fine on the domain, when configured with a static address. It too can ping across to the DHCP server.
The only problem at this point is obtaining a DHCP lease.
I could not find instructions on how to test DHCP connectivity.
Also, we do not have a DHCP relay. I thought that the IP-HELPER setting would take care of this.
Thanks >> Joe
08-12-2014 02:51 PM
Hey Joe,
On the 3750 VTP server switch:
1. Try configuring service dhcp in global configuration mode and check if machine gets an IP address via DHCP,
2. If not, you may need to configure debug dhcp server packet on the 3750 VTP server switch.
HTH.
regards,
RS.
08-12-2014 02:56 PM
Rajeevsh,
The 3750 is acting as a DHCP server for VLAN 3.
Are you suggesting to configure a DHCP scope for VLAN 2 as a test?
08-12-2014 03:00 PM
If 3750 is already DHCP server for vlan 3 so i think creating a test scope for vlan 2 will help narrowing the issue. Try making the switch as DHCP server for vlan 2 as well and check if machine gets an IP address.
RS.
08-13-2014 07:55 AM
Rajeevsh,
Sorry for the false start.
I am remote and the onsite IT spun up the DHCP server. When I checked it, they had left the Allow Filter Policy enabled for the scope with no MAC addresses in the list. This was preventing everything from getting an IP.
DHCP is working now. The switch config was correct after all.
Thanks for the help.
Joe
08-13-2014 01:09 PM
