Problem with "switchport trunk allowed vlan add"
grahammj1
I'm using a SG300-52MP Cisco Layer 3 switch.
Here is the situation - each port is configured with "switchport trunk allowed vlan add 10" (vlan 1 is the default and vlan 10 is our voice vlan).
When the phone boots up - it seems to encounter a broadcast storm (???) the port goes from this:
interface gigabitethernet36
to this:
storm-control broadcast enable
storm-control broadcast level 10
storm-control include-multicast
port security max 10
port security mode max-addresses
port security discard trap 60
spanning-tree portfast
macro description ip_phone
!next command is internal.
macro auto smartport dynamic_type ip_phone
Then in a minute or two I'm no longer able to ping the voicelan - and when I do a show run - gi36 isn't even visible.  However, the PC that is also on gi36 works fine.
If I then reissue the 'switchport trunk allowed vlan add 10' to gi36 - the phone is pingable - and works continuously until the phone is rebooted.
Has anyone encountered this situation before and know how to resolve it? My config is below - any help would be greatly appreciated.
-mjg
config-file-header
switch43f66d
v1.3.0.62 / R750_NIK_1_3_647_260
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end
cdp pdu filtering
no cdp run
no cdp appliance-tlv enable
vlan database
vlan 10
exit
voice vlan id 10
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp relay address 192.168.1.11
ip dhcp relay enable
hostname switch43f66d
interface vlan 1
ip address 192.168.1.5 255.255.255.0
no ip address dhcp
interface vlan 10
ip address 192.168.99.1 255.255.255.0
interface gigabitethernet1-48
interface gigabitethernet49
spanning-tree link-type point-to-point
macro description switch
macro auto smartport dynamic_type switch
exit
no macro auto processing cdp
ip default-gateway 192.168.1.1
grahammj1
Not sure if this helps or not - but the phone worked perfectly all week until the switch had to be rebooted.  Upon reboot, the same thing as above happened.  To get the phone working, all I had to do was issue the 'switchport trunk allowed vlan add 10'.
Any suggestions?
did you save your running config after  adding this command ?
Alain
Thanks for the reply - yes I did save it.  All the other ports have the command.  But when the phone boots up - it ends up disappearing after the above occurs:
to this:
So I'm not really sure what happens during the bootup that causes this to happen, or a way to try and prevent it from occuring.
