Problem with routing at old 2600
gshengel
Hi ppl,
I have nooby problem with my old 2600 router.
I have network as shown at attached picture - My PC (with IP 192.168.0.2/24 and Def GW 192.169.0.1), Cisco 2600 with 2 Ethernet ports (in - E0/1 with IP 192.168.0.1, out - E0/0 with IP 10.244.16.198) and Internet Gateway Server (with in IP 10.244.16.1/24 and out IP 80.xxx.yyy.zzz).
Cisco configuration is:
___START___
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
enable secret 5 XXXXXXXXXXXXXXX
ip subnet-zero
interface Ethernet0/0
ip address 10.244.16.198 255.255.255.0
half-duplex
interface Serial0/0
no ip address
shutdown
interface Ethernet0/1
ip address 192.168.0.1 255.255.255.0
half-duplex
interface Serial0/1
no ip address
shutdown
ip default-gateway 10.244.16.198
ip classless
ip route 0.0.0.0 0.0.0.0 10.244.16.1 permanent
no ip http server
ip pim bidir-enable
line con 0
line aux 0
line vty 0 4
password XXXXXXXXXXX
login
no scheduler allocate
end
___END___
So, from My PC I can ping 192.168.0.1 and 10.244.16.198, but nothing else (even 10.244.16.1). From router I can ping everithyng (even this forum :) ).
Could you please take a look and tell me where is an error?
Thanks in advance!
Jon Marshall
George
You need to NAT your internal 192.168.0.x addresses because they are not routable on the Internet so you won't get any response.
Add this to your config -
int e0/1
ip nat inside
int e0/0
ip nat outside
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
ip nat inside source list 101 interface e0/0 overload
Jon
Jon Marshall
George
int e0/1
ip nat inside
int e0/0
ip nat outside
Jon
I is mirracle! Just copy-paste - and everything started working!
THANKS!!!
