problem with switch 2960
amrashraf1
ihave 4 switch 2960
WS-C2960L-24TS-LL
Version 15.2(6r)E1
i have 4 floor in every floor have one of 2960 and all of them conncted with core switch 3650 but
switches 2960 some times need restart often one restart per day what is the poblem
26 Replies 26
u mean need configration for this switch
show controllers cpu-interface
this show us if there is broadcast storm or not in SW, can you share the output?
amrashraf1
this is on core sw
amrashraf1
any reply if there is broad cast
Hi friend
sorry for late reply, i check the info you send just add this command under each VLAN and se if the SW will hung anymore or not.
no ip redirects
#no ip redirect
what this command make
and when i send output of command                      #show controllers cpu-interface
u see bc or what ??
If this switch is still rebooting after a firmware upgrade, then I suspect the issue is the power source.
Here is an easy test, plug another switch to the same power source and observe if the 2nd switch reboots the same time as the original one.
do show controller cpu-interface
inter the command
on ip redirect
do show controller cpu-interface again and again check see if the counter of ICMP redirect increase
this output,
there is increment in icmp redirect and this output as you mention after reboot SW.
no ip redirect prevent SW send icmp redirect message to host when there is other path.
I see broadcast but the number 230000 is not near Forus Traffic 22000 "Forus traffic mean the traffic handle by software not hardware of SW" so i think it is normal.
thank u very much i will try everything u said it and iwill tell u
first you are so so welcome
second update me when you can
good luck friend
I thinnk my build have unstable electricity
The electricity flapping every day but the switch dosnot restart. flapping is very fast  so my switch dont turn off this may cause hang my switch true !!!!   but i upgraded all switches to see if the ios version is the problem or not
