problem with switch 3960G sfp fiber
Nader Elmansi
salam
i have two switches 3960G and i try to make uplink with them by using sfp fiber but they didenot connect
all thing work right and i checked it "fiber link , pach cord fiber ,swiches "
only sfp link not work
some one tell me my  it disabeled by default
note : the switches are new and it is first time to work and no previous configuration
thanks
mvsheik123
Level 7
Level 7
Please post both end interface configs (fiber ports). Also, make sure switch recognises the gbic. Do 'Show inter xx' it should tell you the gbic.
Thx
MS
Leo Laohoo
On both switches, can you please post the output to the following commands:
1.  sh version;
2.  sh logs;
3.  sh interface status
darren.g
Level 5
Level 5
Nader Elmansi wrote:
salam
thanks
Are you sure of that model type? I can't find any switch with the model 3960G - are you sure they're not 2960G?
Anyway, have you tried the command "media-type sfp" on the ports you're using for the fibre link?
Cheers
