Problem with synchoronization with SSM-On-Prem
xklima6
Catalyst 9200 cannot sync with SSM-On-Prem.
I can ping and ssh to SSM-On-Prem from my switch.
from switch:
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Account Information:
Smart Account: <none>
Virtual Account: <none>
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: cslu
Cslu address: https://172.25.100.250/cslu/v1/pi/Test-1
Proxy:
Not Configured
VRF: <empty>
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Miscellaneous:
Custom Id: <empty>
Usage Reporting:
Last ACK received: <none>
Next ACK deadline: Dec 10 06:58:10 2024 UTC
Reporting push interval: 30 days
Next ACK push check: <none>
Next report push: Sep 11 07:00:10 2024 UTC
Last report push: <none>
Last report file write: <none>
Trust Code Installed: <none>
From SSM-On-Prem in Inventory - Product Instances
Unable to connect. Provide correct Host/IP of the product instance and make sure HTTPS is configured.
Hello
Just to confirm, your on prem ssm can reach CSSM okay, this issue is your local switch not able to reach you on prem ssm correct - if so  check this link,
Kind Regards
Paul
Your soluttion did not help.
Yes my SSM-On-Prem can reach CSSM. The problem is that switch wont sync with SSM-On-Prem (SSH, ping are working). The problem that is written in SSM-On-Prem in my inventory:
"Unable to connect. Provide correct Host/IP of the product instance and make sure HTTPS is configured."
