problem with telnet to router
ravi mishra
i am unable to telnet to my router.whenever i telnet to it, i get a black screen without any login prompt and when i press enter in the blank screen it returns back to my cmd prompt.
i have enabled transport input telnet in my line vty 0 4.
Reza Sharifi
What application are you using to connect? Try using putty or SecureCRT to connect.
Can you post config for vty line 0 4?
line vty 0 4
access-class 27 in
privilege level 15
password 7 0234a1912234cd1258
login
access list 27 has our specific clients ip and wildcard specified and implicit deny at end
when i did sh ip access-list 27, i got hits from the ips in access list but it connects to blank screen and then goes back to cmd while telnetting
Thanks for the partial config. It does help us understand a bit better. But it does not tell us enough. Could you post the complete config (with passwords and other sensitive information masked out)? For example we need to know whether you have configured aaa new-model which changes the default method of authenticating telnet sessions.
Rick
Rick
 For test purpose remove ACL. That will help you to understand if this problem is related to ACL settings or not.
Or as option, publish the ACL 27 and IP you are connecting from.
And result of
CMD>tracert -d X.X.X.X
Where X.X.X.X -s your ROUTER IP
