Problem with Time-Domain Reflectometer (TDR)
Markus.Richter
Community Member
We have an C3560CG-8PC-S Switch with ios version 12.2(55)EX3.
I've tried to investigate a connection problem using the tdr tool.
It shows the following result from which I can't drag any useful information:
Interface Speed Local pair Pair length        Remote pair Pair status
Gi0/3     100M  Pair A     N/A                N/A         Not Completed
                Pair B     N/A                N/A         Not Completed
                Pair C     N/A                N/A         Not Completed
                Pair D     N/A                N/A         Not Completed
Port Speed is 100M, PoE is on an used with app. 7.0W
Can anyone help me out with this?
Thx in advance!
5 Replies 5
Leo Laohoo
On a 3560-series family of switches, sometimes a TDR takes a whopping 61 seconds before you issue the "sh cable tdr interface" command.
I've tried waiting some time before issuing the "sh cable-diag tdr interface ..." command.
But even after an hour nothing changend 😞
Markus,
TDR and 3560 ... they don't mix well.  Sometimes the feature works, sometimes it won't.
Normally when I see this, I just change the cables at both ends.
Thx Leo,
too bad 😞
Changing the cables was task anyway due to connection problems.
Oh, and upgrade your IOS.  The EX "series" of IOS is not designed for long-term production.  I like to call the EX-series of IOS as an interim-only IOS.  The objective is to get your switch "stable" (or close to) so you get it working until the main-line IOS is available.
I'd recommend you look at upgrading to 15.0(2)SE4.
