10-05-2011 12:24 AM - edited 03-07-2019 02:36 AM
Hello
I recently changed my company's router with a cisco 1941 k9 and i have a problem......
I have two networks the 192.168.1.0/24 in gig0/0 and 10.69.0.0/16 in gig0/1 Both networks have static ips
The most of the hosts are under the 10.69.0.0 but my dns server has ip 192.1.1.144 the problem is that although i can ping from one network to other i can not resolve netbios names from the network 10.69.0.0.
I already configured the ip helper-address to gig0/1
Any clue why is this happening???
Solved! Go to Solution.
10-05-2011 06:11 AM
no not for netbios resolution unless you want to send your hosts a WINS server IP address.
Can you try using ip helper-address to directed broadcast IP and get sure directed broadcast are enabled on interface.
Regards.
Alain.
10-05-2011 12:45 AM
ip helper-address is only to send the requests to DHCP server, this is not for dns resolve.
You need to configure the domain-name and name server under the DHCP config.
ip dhcp pool OFFICE
network 192.168.12.0 255.255.255.0
domain-name networkers-online.com
default-router 192.168.12.1 !– gateway address
dns-server 192.168.12.100 192.168.12.101 !– DNS servers
netbios-name-server 192.168.12.99 !– WINS servers
lease 2 !– lease time
Please rate the helpful posts.
Naidu.
10-05-2011 01:27 AM
Both of my networks use static ips, there is no DHCP in my network, Do i still have to configure dhcp pool ???
10-05-2011 06:11 AM
Regards.
Alain.
10-05-2011 11:46 PM
I already have configured the ip helper-address to redirect all the broadcasts to my wins server how do i enable the directed broadcasts to an interface??
10-06-2011 03:08 AM
Thank you for your help !!!!! you were right i had only configured the ip helper address without broadcast forwarding
10-06-2011 02:19 AM
hi evangelos,
have you entered the dns-server ip manually at the workstations? cause then it should work, as if the clients know the ip address of dns server they dont generate a broadcast at all and therefore the router should route the packtes.
alternatively you can also edit your "lmhost" file on the workstations.
HTH,
florian
10-06-2011 03:12 AM
Thank you for your reply alain was right it worked
