problem with VACL
mohammed alsaadi
Frequent Visitor
Frequent Visitor
HI
I’m try to apply VACL on a switch 3560-c, the configuration as the following
Building configuration...
Current configuration : 1276 bytes
! Last configuration change at 00:35:46 UTC Mon Jan 2 2006
version 15.0
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
vtp mode transparent
spanning-tree mode pvst
vlan access-map map 10
 match ip address 100
 action forward
vlan access-map map 20
 action drop
vlan filter map vlan-list 1
vlan internal allocation policy ascending
vlan 100-103,110,200
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 ip address 10.10.10.100 255.255.255.0
ip http server
ip http secure-server
ip access-list extended valn1
 permit ip host 10.10.10.10 host 10.10.10.20
 permit ip host 10.10.10.20 host 10.10.10.10
line con 0
line vty 5 15
end
When I ping from 10.10.10.10 to 10.10.10.20,it success for approx.  5minutes then  "requset time out "
Please I need help
dukenuk96
Level 7
Level 7
configuration seems correct, try to enable logging for drops, if it does not reveal anything, run sniffer on both machines and look what happens when timeouts come back.
Hello
You extended ACL isn't being called in the VACL
res
Paul
Kind Regards
Paul
Dear Paul
you right , i correct it but that is not solving the problem .
i did some search , i found that i need to add mac access-list
permit any any 0x0806 0x0000
permit any any lsap 0xAAAA 0x0000
and add it in vlan access map , with this lines there is no problem
for more look at this
http://cauew.blogspot.com/2008/08/vacl-vlan-maps-mac-acl.html?m=1
thanks all
