Problem with VTP in packtracer
mamdouhdayem
I run a VTP on my own lap while I'm practicing for CCNA exam, the problem is that the VLANs on my switch1 (SW6) did not moved or transfer to the other switch(SW6) please what is the problem here :
i'm using packtracer and i want to run VTP and TRUNk to allow all the VLANs on SW1 to move to SW6.
switch model 2960
i need your help.....
SW1
SW1#show running-config
Building configuration...
Current configuration : 1401 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname SW1
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
username Mamdouh privilege 1 password 0 mamdooh
spanning-tree mode pvst
interface FastEthernet0/1
interface FastEthernet0/2
switchport access vlan 10
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
switchport mode trunk
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0006.2a4a.1301
ip address 192.168.1.100 255.255.255.0
line con 0
password cisco
login
exec-timeout 0 0
line vty 0 4
password cisco
login local
line vty 5 15
login
end
SW1#
SW6#show running-config
Current configuration : 1816 bytes
version 12.2
hostname SW6
vtp domain TEST1
vtp mode transparent
switchport mode access
interface Vlan1
ip address 192.168.1.50 255.255.255.0
line con 0
password cisco
login
exec-timeout 0 0
line vty 0 4
password cisco
login local
line vty 5 15
login
end
SW6#
Mohsin Alam
Make sure to define same VTP domain name on both switches , from the config i see only S6 having VTP name.
## Make sure to mark post as helpful. ##
## Make sure to mark post as helpful, If it resolved your issue. ##
mHadi
make sure the links between all switches is Trunk,
then about VTP configs, you need at least one Switch to be VTP mode server,
and other switches can be VTP mode client,
also, VTP Domain, Password and version on all switches MUST BE SAME..
(HTH)
(if this helps, please rate..)
Mohammadreza Hadi
