invalid input detected at '^' marker while creating vlan on catalyst 3500 series xl
keeran
Hallo Experts,
I have possibly a very basic question.
Whilst i was trying to create vlan on catalyst 3500 series XL switch i got this "invalid input detected.." error which showed the vlan command as invalid.  This is how i started:
    switch> ena
    switch# conf t
    switch# vlan 51
and it showd the vlan command as invalid.
Why  can't i configure vlan ?
That is a REALLY OLD switch, and you don't access the vlan configuration from normal config mode. From a privileged exec prompt, use "vlan database" to configure the vlan's.
Reza Sharifi
When you enter config t, it should put you in the config mode
(config)#
Do you get an error when you try?
config t
Thank you for the help. I knew my swtich was old but didn't think it is so old that i have to do it with vlan databse :). Thank you again.
