Problems with EHWIC-4ESG card
Reedik Leitsar
i have cisco Cisco 1921 (CISCO1921/K9) and i brouht additional switch card to it but Router does not
support it because of IOS software, i found from forums that software needed is 15.2 ,our cisco is running Version 15.0(1)M4 of IOS. So i wanted to upgrade it but every software i take Cisco CP gives me an error that this software is no supported on your Device, is it okay to ignore the warning ?
Show diag :
        WIC Slot 0:
        Unknown WAN daughter card
        WIC module not supported/disabled in this slot
        PCB Serial Number        :
        Hardware Revision        : 1.0
        Part Number              : 74-7105-01
        Board Revision           : C0
        Deviation Number         : 0
        Product (FRU) Number     : EHWIC-4ESG
        Version Identifier       : V01
        CLEI Code                : COUIA46CAA
        Base MAC Address         : 8843.e1b4.9908
        MAC Address block size   : 8
        EEPROM format version 4
        EEPROM contents (hex):
0 Replies 0
