11-05-2018 08:04 AM - edited 03-08-2019 04:32 PM
Have a Cisco IE-3000-8TC switch with module IEM-3000-4SM but any FastEthernet ports doesn't works just the two GigabitEthernet ports works, please any help
11-05-2018 08:19 AM
- Doesn't work can mean many things; can you describe that in network-technical-terms ?
M.
11-05-2018 08:32 AM
11-06-2018 12:11 AM
- Are the port settings correct for the intended usage of the particular fastethernet port ? Also after a connection is made issue show logging on the switch, watch out for any additional error info, if any.
M.
