Problems with InterVLAN routing on Single Switch
steve2like
Community Member
Hello all,
I am currenlty trying to set up InterVLAN routing and failing.
I have a single Catalyst 3750G switch in which I want to configure two VLANs and route between them.
Firewall: 192.168.100.1 255.255.255.0
Vlan 1: 192.168.100.2 255.255.255.0
Vlan 2:  192.168.101.1 255.255.255.0
Host A: 192.168.100.3 255.255.255.0
Host B: 192.268.101.2 255.255.255.0
I have successfuly created VLAN 1 & 2.  From the switch I can ping both 192.168.100.1 & 192.168.101.1.  From the switch I can also ping both Host A & Host B.  From Host A I can't ping Host B and vice versa.
I have enable the ip route command. There are no access control lists that would prevent communication.
Ideas?
10 Replies 10
Jan Rolny
Level 8
Level 8
Hi James,
it seems you don't have default gateway configured on hosts.
Can you please confirm that you have configure default gateway on host computers and also could you please post configuration of your switch?
Jan
Jan,
Thanks for the reply. I can confirm that both hosts have a default gateway:
Host A: 192.168.100.3 255.255.255.0  DG 192.168.100.1
Host B: 192.268.101.2 255.255.255.0  DG 192.168.101.1
Hi James,
ok so you want to filter access between vlans and thats' why you have configured for default gw IP of your Firewall.
Because if you just wnat to make simple interVlan routing without filtering you can setup default gw to IP address of vlan interface where host resides.
Jan
Hello
can you please post your configuration of this switch?
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
cadet alain
To confirm intervlan routing is ok try to ping vlan 2  interfacesourcing from vlan 1 interface.
if it is ok then try to disable software firewalls on hosts and try to ping from host A to host B
Alain
Ankur Arora
Level 7
Level 7
James,
Change the default gateway on the Hosts to the SVI of the respective VLANs.
Turn off the windows firewall on both the hosts. Firewall create lots of connectivity issues.
Ankur
"Please rate the post if found useful"
Martin Carr
Level 8
Level 8
On host A the G/W is the firewall, this should be the SVI.
Martin.
Many thanks Martin and Ankur. I changed the G/W on Host A and now it can communicate with Host B.
Now my problem is that Host B cannot communicated with the firewall 172.23.10.1.
Any further ideas?
James
Do you have a route on the firewall for the 192.168.101.0/24 subnet. Don't know what make your firewall is but basically you need to tell it to get to 192.168.101.0/24 it needs to send packets to 192.168.100.2. If the firewall was an ASA it would be -
route inside 192.168.101.0 255.255.255.0 192.168.100.2
assuming the name of the interface was "inside".
Jon
You need to have a return route on the firewall, pointing towards the SVI on the switch as the firewall is not aware of the other subnet/vlan. So you point the firewall towards the network address via the next hop as mentioned by Jon.
Ankur
