Problems with Multiple 350 Clients and LinkSys WAP11 AP
gumlygumly
I am hoping someone can help. I seem to be able to configure a single Aironet350 PCMCIA card to work with a LinkSys WAP11 AP, but cannot seem to get 2 of them working together. I have gone thru and tried all the obvious stuff and even diabled WEP and I cannot seem to get the second laptop with 350 client card to work. I also notice in the ACU of the one that does work, that the SSID does not appear - only as * No Name Specified * . It is specified in the AP.
Any help would be appreciated. The error when I run a troubleshooting test on the connection is that the it cannot find a DHCP server. The IP address is initially 0.0.0.0 and it may eventually get a 169.x.x.x. Any help would be appreciated.
Mick Garrett
mchin345
Level 6
Level 6
you cannot enable Aironet Extensions without blocking the non-Cisco adapters from authenticating.Check with the DHCP Timouts, it may be the less time.Check with OS that you installed in Laptop.Otherwise go for Upgrading the latest firmware.
