Putty HOME and END keys don't work
Tim Schroeder
Level 4
Level 4
Does anyone know how to configure Putty or the Cisco console such that HOME and END keys work properly when typing commands in a router via SSH or Telnet? I know you can use Ctrl-A and Ctrl-E but it would be nice if Home and End worked correctly.
Seb Rupik
Hi Tim,
When you configure a new session, in the settings go to Connections -> Data , change the 'Terminal-type string' to putty .
cheers,
Seb.
