PXE Boot does not work - No DHCP addrress received (works fine with in Windows Guest)
ALSIC
We're experiencing a bizar problem with pxe booting a windows 2016 server from a hyper-v environment.
We are not getting any IP address from the DHCP server, but when booting normal into the windows os the DHCP server does gives the server an IP address...
The DHCP server is also a windows server an on another vlan.
The PXE server is on the same vlan 115 as de server that needs to pxe boot.
There are DHCP relay server(s) configured on the vlan 115 where the windows server that needs to pxe boot.
There are 2 Cisco Nexus switches that are providing redundant connection.
Below is the version and some configuration.
Could anyone help?
Thanks.
show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2015, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
BIOS: version 2.1.7
loader: version N/A
kickstart: version 7.0(7)N1(1)
system: version 7.0(7)N1(1)
Power Sequencer Firmware:
Module 1: version v4.0
Module 2: version v4.0
Fabric Power Sequencer Firmware: Module 1: version v4.0
Microcontroller Firmware: version v0.0.0.15
QSFP Microcontroller Firmware:
Module 2: v2.0.0.0
Module 1: v1.3.0.0
BIOS compile time: 06/16/2016
kickstart image file is: bootflash:///n6000-uk9-kickstart.7.0.7.N1.1.bin
kickstart compile time: 8/24/2015 22:00:00 [08/25/2015 13:47:41]
system image file is: bootflash:///n6000-uk9.7.0.7.N1.1.bin
system compile time: 8/24/2015 22:00:00 [08/25/2015 13:49:21]
Hardware
cisco Nexus 5672UP Chassis ("Nexus 5672UP Supervisor")
Intel(R) Xeon(R) CPU @ 1.80 with 8243352 kB of memory.
Processor Board ID FOC19040HZ4
Device name: SW-FER01
bootflash: 8028160 kB
Kernel uptime is 9 day(s), 5 hour(s), 2 minute(s), 31 second(s)
Last reset
Reason: Unknown
System version: 7.0(7)N1(1)
Service:
plugin
Core Plugin, Ethernet Plugin, Fc Plugin
service dhcp
ip dhcp relay
interface Vlan115
description Servers5_Ferraris
no shutdown
no ip redirects
ip address 172.17.3.2/24
ip router rip VMM
ip rip passive-interface
ip proxy-arp
hsrp 1
preempt
priority 110
ip 172.17.3.1
ip dhcp relay address 172.17.1.1
ip dhcp relay address 172.17.2.71
ip dhcp relay address 172.17.3.56
ip dhcp relay address 172.17.3.153
115 VLAN0115 active Po5, Po6, Po7, Po8, Po9, Po11
Po29, Po30, Po256, Eth1/5
Eth1/6, Eth1/7, Eth1/8, Eth1/9
Eth1/10, Eth1/15, Eth1/18
Eth1/19, Eth1/20, Eth1/21
Eth1/22, Eth1/29, Eth1/30
Eth2/1, Eth2/2, Eth100/1/1
Eth100/1/2, Eth100/1/3
Eth100/1/6, Eth100/1/7
Eth100/1/8, Eth100/1/14
Eth100/1/15, Eth100/1/16
Eth101/1/1, Eth101/1/2
Eth101/1/3, Eth101/1/6
Eth101/1/7, Eth101/1/8
Eth101/1/14, Eth101/1/15
Eth101/1/16, Eth111/1/1
Eth111/1/2, Eth111/1/3
Eth111/1/4, Eth111/1/5
Eth111/1/7, Eth111/1/9
Eth111/1/10, Eth111/1/11
Eth111/1/12, Eth111/1/13
Eth111/1/14, Eth111/1/15
Eth111/1/16, Eth111/1/17
Eth111/1/18, Eth111/1/19
Eth111/1/20, Eth111/1/22
Eth111/1/23, Eth111/1/24
Eth111/1/29, Eth112/1/1
Eth112/1/3, Eth112/1/4
Eth112/1/6, Eth112/1/7
Eth112/1/8, Eth112/1/9
Eth112/1/10, Eth112/1/12
Eth112/1/13, Eth112/1/14
Eth112/1/15, Eth112/1/16
Eth112/1/17, Eth112/1/18
Eth112/1/19, Eth112/1/20
Eth112/1/22, Eth112/1/23
Eth112/1/24, Eth112/1/29
interface Ethernet1/1
switchport mode fex-fabric
fex associate 100
channel-group 100
interface Ethernet1/2
fex associate 100
channel-group 100
interface Ethernet1/3
fex associate 101
channel-group 101
interface Ethernet1/4
fex associate 101
channel-group 101
interface Ethernet1/5
switchport mode trunk
spanning-tree link-type point-to-point
spanning-tree guard loop
speed 1000
storm-control broadcast level 5.00
interface Ethernet1/6
speed 1000
interface Ethernet1/7
switchport trunk native vlan 803
speed 1000
channel-group 7 mode active
interface Ethernet1/8
speed 1000
channel-group 8 mode active
interface Ethernet1/9
speed 1000
channel-group 9 mode active
interface Ethernet1/10
switchport access vlan 115
speed 1000
interface Ethernet1/11
switchport trunk allowed vlan 1,221-222
speed 1000
channel-group 10 mode active
interface Ethernet1/12
speed 1000
interface Ethernet1/13
no cdp enable
switchport access vlan 61
spanning-tree port type edge
speed 1000
duplex full
flowcontrol receive on
interface Ethernet1/14
no cdp enable
switchport access vlan 62
speed 1000
duplex full
interface Ethernet1/15
no cdp enable
speed 1000
duplex full
interface Ethernet1/16
no cdp enable
switchport access vlan 70
speed 1000
duplex full
interface Ethernet1/17
no cdp enable
switchport access vlan 71
speed 1000
duplex full
interface Ethernet1/18
switchport trunk native vlan 800
switchport trunk allowed vlan 1-120,122-800,802-4094
speed 1000
duplex full
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
fex associate 112
channel-group 112
interface Ethernet1/26
fex associate 112
channel-group 112
interface Ethernet1/27
fex associate 111
channel-group 111
interface Ethernet1/28
fex associate 111
channel-group 111
interface Ethernet1/29
channel-group 29 mode active
interface Ethernet1/30
channel-group 30 mode active
interface Ethernet1/31
no switchport
channel-group 255 mode active
interface Ethernet1/32
no switchport
interface Ethernet2/1
spanning-tree port type network
channel-group 256 mode active
interface Ethernet2/2
interface Ethernet2/3
interface Ethernet2/4
interface Ethernet2/5
interface Ethernet2/6
interface mgmt0
speed 100
duplex full
no lldp transmit
no lldp receive
vrf member management
ip address 172.17.8.40/24
interface Ethernet100/1/1
no lldp transmit
no lldp receive
switchport trunk native vlan 117
switchport trunk allowed vlan 62,111-115,117,1000-1001,1010,4080
interface Ethernet100/1/2
no lldp transmit
no lldp receive
interface Ethernet100/1/3
no lldp transmit
no lldp receive
interface Ethernet100/1/4
interface Ethernet100/1/5
interface Ethernet100/1/6
no lldp transmit
no lldp receive
switchport trunk allowed vlan 62,111-117,1000-1001,1010,4080
interface Ethernet100/1/7
no lldp transmit
no lldp receive
interface Ethernet100/1/8
no lldp transmit
no lldp receive
interface Ethernet100/1/9
interface Ethernet100/1/10
interface Ethernet100/1/11
interface Ethernet100/1/12
interface Ethernet100/1/13
interface Ethernet100/1/14
no lldp transmit
no lldp receive
interface Ethernet100/1/15
no lldp transmit
no lldp receive
interface Ethernet100/1/16
no lldp transmit
no lldp receive
interface Ethernet101/1/1
interface Ethernet101/1/2
interface Ethernet101/1/3
interface Ethernet101/1/4
interface Ethernet101/1/5
interface Ethernet101/1/6
interface Ethernet101/1/7
interface Ethernet101/1/8
interface Ethernet101/1/9
interface Ethernet101/1/10
interface Ethernet101/1/11
interface Ethernet101/1/12
interface Ethernet101/1/13
interface Ethernet101/1/14
interface Ethernet101/1/15
interface Ethernet101/1/16
interface Ethernet111/1/1
no cdp enable
interface Ethernet111/1/2
no cdp enable
interface Ethernet111/1/3
no cdp enable
interface Ethernet111/1/4
no cdp enable
interface Ethernet111/1/5
no cdp enable
speed 10
interface Ethernet111/1/6
no cdp enable
switchport access vlan 112
interface Ethernet111/1/7
no cdp enable
interface Ethernet111/1/8
no cdp enable
interface Ethernet111/1/9
no cdp enable
interface Ethernet111/1/10
no cdp enable
interface Ethernet111/1/11
no cdp enable
interface Ethernet111/1/12
no cdp enable
interface Ethernet111/1/13
no cdp enable
interface Ethernet111/1/14
no cdp enable
interface Ethernet111/1/15
no cdp enable
interface Ethernet111/1/16
no cdp enable
interface Ethernet111/1/17
no cdp enable
interface Ethernet111/1/18
no cdp enable
interface Ethernet111/1/19
no cdp enable
interface Ethernet111/1/20
no cdp enable
interface Ethernet111/1/21
no cdp enable
switchport access vlan 8
interface Ethernet111/1/22
no cdp enable
spanning-tree bpdufilter enable
channel-group 11 mode active
interface Ethernet111/1/23
no cdp enable
speed 1000
duplex full
interface Ethernet111/1/24
no cdp enable
interface Ethernet111/1/25
no cdp enable
interface Ethernet111/1/26
no cdp enable
interface Ethernet111/1/27
no cdp enable
interface Ethernet111/1/28
no cdp enable
interface Ethernet111/1/29
no cdp enable
interface Ethernet111/1/30
no cdp enable
interface Ethernet111/1/31
no cdp enable
interface Ethernet111/1/32
no cdp enable
interface Ethernet111/1/33
no cdp enable
interface Ethernet111/1/34
no cdp enable
interface Ethernet111/1/35
no cdp enable
interface Ethernet111/1/36
no cdp enable
interface Ethernet111/1/37
no cdp enable
interface Ethernet111/1/38
no cdp enable
interface Ethernet111/1/39
interface Ethernet111/1/40
interface Ethernet111/1/41
no cdp enable
switchport access vlan 101
interface Ethernet111/1/42
no cdp enable
interface Ethernet111/1/43
no cdp enable
interface Ethernet111/1/44
no cdp enable
interface Ethernet111/1/45
no cdp enable
interface Ethernet111/1/46
no cdp enable
interface Ethernet111/1/47
no cdp enable
interface Ethernet111/1/48
no cdp enable
interface Ethernet112/1/1
no cdp enable
interface Ethernet112/1/2
no cdp enable
interface Ethernet112/1/3
no cdp enable
interface Ethernet112/1/4
no cdp enable
interface Ethernet112/1/5
no cdp enable
interface Ethernet112/1/6
no cdp enable
interface Ethernet112/1/7
no cdp enable
interface Ethernet112/1/8
no cdp enable
interface Ethernet112/1/9
no cdp enable
interface Ethernet112/1/10
no cdp enable
interface Ethernet112/1/11
no cdp enable
interface Ethernet112/1/12
no cdp enable
interface Ethernet112/1/13
no cdp enable
interface Ethernet112/1/14
no cdp enable
interface Ethernet112/1/15
no cdp enable
interface Ethernet112/1/16
no cdp enable
interface Ethernet112/1/17
no cdp enable
interface Ethernet112/1/18
no cdp enable
interface Ethernet112/1/19
no cdp enable
interface Ethernet112/1/20
no cdp enable
interface Ethernet112/1/21
no cdp enable
speed 100
duplex full
interface Ethernet112/1/22
no cdp enable
interface Ethernet112/1/23
no cdp enable
speed 1000
duplex full
interface Ethernet112/1/24
no cdp enable
interface Ethernet112/1/25
no cdp enable
interface Ethernet112/1/26
no cdp enable
interface Ethernet112/1/27
no cdp enable
interface Ethernet112/1/28
no cdp enable
interface Ethernet112/1/29
no cdp enable
interface Ethernet112/1/30
no cdp enable
interface Ethernet112/1/31
no cdp enable
interface Ethernet112/1/32
no cdp enable
speed 100
duplex full
interface Ethernet112/1/33
no cdp enable
interface Ethernet112/1/34
no cdp enable
interface Ethernet112/1/35
no cdp enable
interface Ethernet112/1/36
no cdp enable
interface Ethernet112/1/37
no cdp enable
interface Ethernet112/1/38
no cdp enable
interface Ethernet112/1/39
no cdp enable
interface Ethernet112/1/40
interface Ethernet112/1/41
no cdp enable
interface Ethernet112/1/42
no cdp enable
interface Ethernet112/1/43
no cdp enable
interface Ethernet112/1/44
no cdp enable
interface Ethernet112/1/45
no cdp enable
interface Ethernet112/1/46
no cdp enable
interface Ethernet112/1/47
no cdp enable
interface Ethernet112/1/48
no cdp enable
Eric101
Not 100% clear on your setup.
Is your booting VM expected to go to your Windows DHCP server on another subnet to get it's initial address and boot loader options?
Or is there another DHCP instance which you have called the PXE server in the same subnet which should handle the initial configuration?
Have you done a packet capture to see if your the DHCPDiscover is making it to your DHCP server and responses sent back?
Yes the booting VM is expected to go to the Windows DHCP server on another subnet to get it's initial IP address and bootloader options and then download the image from the PXE server (Citrix Provisioning) on the same subnet.
I've also tried with the DHCP service enabled (and al the specifics configured) on the PXE server in the same subnet, but it won't work.
Haven't done a capture yet. I suppose you're reffering to a wireshark capture on the DHCP server?
I would normally try to capture as close to the booting machine as possible to begin with, particularly as you indicated that DHCP seemed to work with other machines in the subnet and look for the DHCP transaction messages (DHCPDISCOVER, DHCPOFFER, DHCPREQUEST and DHCPACK)
If it goes through the whole exchange, then you're likely looking at a problem with your DHCP options or client machine.
If you see DHCPDISCOVER, but no offer, then you'll want to move to the server to confirm that the message is being relayed and responded.
If not relayed there is a problem on the switch, as it is a NX-OS make sure that feature dhcp is enabled [command: show feature] (I did not see it in your config snippets, but you say it was working with other devices)
Check the status of the dhcp relay [command: show ip dhcp relay] and gather any statistics [command: show ip dhcp relay statistics] and paste here.
