Q in Q protocol use
krunallakhani
Can someone please explain a defination and usage of Q in Q protocol.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
This might be answered better in https://learningnetwork.cisco.com/welcome, however Q in Q is basically a frame with two VLAN tag headers.  It's often used with L2 MetroE providers.  It allows the provider to have their own VLANs distinct from customer VLANs running across their network.  For example, on the MetroE provider network VLAN 5 contains all customer X's traffic while VLAN 6 contains all customer Y's traffic, yet both customer X and customer Y are using many VLANs, possibly including VLANs 5 and/or 6.
Joseph W. Doherty
Disclaimer
Posting
I also wanted to know what are the prerequestists should be available in your device to support this. As ISP is providing Ethnert and they said you have to use Q in Q protocol as cant configure the Ethernets with portchannels as its coming with diff providers.
Can someone please guide. what are the prerequestist or devices support needed to support Q in Q protocol
Disclaimer
Posting
As I recall (? - but it's been years), you just hand off "normal" tagged frames to the service provider.  It's they who need Q-in-Q support.  Whether equipment supports Q-in-Q is up to the equipment.  If you need it, you would need to use equipment that's known to support it.
krunallakhani
