QinQ termination vlan
Elbrabra
I have to peer with a cloud services with the use of QinQ (802.1ad).
We have a router Catalyst 4500-X connected to our service provider. The cloud services gave us this sample configuration to use on our router:
interface TenGigabitEthernet1/1/11.100
encapsulation dot1q 3000 second-dot1q 100
ip address 10.10.10.1 255.255.255.0
dot1q tunneling ethertype 0x88A8
Problem Catalyst 4500-X doesn't support subinterfaces.
So I found an another solution with SVI but it's not working.
This is the configuration I made (on the 4500X) in the interface facing the service provider:
description TO_CLOUD
switchport mode trunk
switchport vlan mapping 100 dot1q-tunnel 3000
end
And I create an interface vlan 100:
interface vlan 100
description cust-vlan
end
Customer vlan = 100
SP vlan = 3000
Any idea about the issue ?
I attached a diagram showing my interconnection with the SP.
I am not sure if this works at all. Try the additions (in bold) below:
switchport access vlan 100
switchport trunk allowed vlan all
Hello Georg,
Thank you for your help, I tried to add configuration in bold in my interface but I can't ping the peer IP (10.10.10.2). I learn a mac from the cloud peering but it's stored in vlan 1 inside router"s cam.
I captured traffic using the monitor capture feature on Cata 4500-X I saw arp request from cloud services with the correct tag information in the packet (3000 for S-vlan and 100 for Cust vlan).
When I did a ping I saw an arp request sent by the router but I can't verify tag information because monitor feature operate before encapsulation.
have you already deploy this kind of feature (selective QinQ ) ?
dperezoquendo
Can you verify the native vlan on both your side and the service provider? And try enabling native vlan tagging globally and on interface?
global command = vlan dot1q tag native
 switchport trunk native vlan ###
 switchport trunk allowed vlan 3000
mperozamarval
Hey!  Were you able to fix this?  I am having a similar problem!
