12-13-2016 11:38 AM - edited 03-08-2019 08:33 AM
Can anyone advise if I should add QOS to interfaces between 3750 and 2921 VG?
* 3750 - core
* 2921 - PSTN gateway
Current settings are:
| 3750 | 2921 |
interface GigabitEthernet1/0/15
description <<UK-PSTN-01 Gi0/0>>
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
duplex auto
speed auto
Also QOS Maps
| 3750 | 2921 |
Dscp-cos map:
d1 : d2 0 1 2 3 4 5 6 7 8 9
0 : 00 00 00 00 00 00 00 00 01 01
1 : 01 01 01 01 01 01 02 02 02 02
2 : 02 02 02 02 03 03 03 03 03 03
3 : 03 03 04 04 04 04 04 04 04 04
4 : 05 05 05 05 05 05 05 05 06 06
5 : 06 06 06 06 06 06 07 07 07 07
6 : 07 07 07 07
Cos-dscp map:
cos: 0 1 2 3 4 5 6 7
dscp: 0 8 16 26 32 46 48 56
Dscp-cos map:
dscp: 0 8 10 16 18 24 26 32 34 40 46 48 56
cos: 0 1 1 2 2 3 3 4 4 5 5 6 7
Cos-dscp map:
Solved! Go to Solution.
12-14-2016 04:52 AM
Hello Tom,
in addition to all the other suggestions, this link provides examples for various CoS maps on different platforms and traffic types:
http://www.dslreports.com/faq/13324
12-13-2016 12:13 PM
If there's nothing but VoIP traffic on that link, there's almost no benefit to having QoS. However, as the 3750 is an all ports or no ports QoS, if QoS is globally enabled, you may want to customize its port settings to the 2921.
On the 2921, you can do per port QoS, but again, if the only traffic on the port to the 3750 is VoIP, very, very little benefit and using QoS (assuming you don't need to remark traffic or some such).
12-14-2016 02:55 AM
Thanks Joseph
It is only VOIP and router management traffic. QOS is already enabled on the 3750. Can you recommend any particular settings to apply to the 3750 port connecting to 2921?
Tom
12-14-2016 04:20 AM
You could use a different queue-set to optimize buffer resources for the queue(s) being used between the 3750 and 2921. Also, if your management traffic comprises "stuff" like SNMP stats and an IGP. You should prioritize VoIP and the IGP over SNMP. How VoIP and IGP should be prioritized relative to each other, can be a little more difficult to determine. I.e. if either, if using PQ can starve the other, perhhaps PQ shouldn't even be used for either.
12-14-2016 04:52 AM
Hello Tom,
12-13-2016 12:27 PM
are you asking if you should configure QoS on the link between the 3750 and the 2921 (or is it a 2960) ? Do you already have 'mls qos' configured globally, and e.g. auto qos ?
