QOS between routed interfaces
wbarren
I am setting up QOS out to my MPLS network but do not seem to be passing dscp values between my 4500 and 3800 router. I have the interfaces setup as follows. When I run a sh policy-map int on my wan interface it does not show the voice traffice going through the voice service que.
4500
interface GigabitEthernet4/46
no switchport
ip address x.x.x.x x.x.x.x
speed 1000
duplex full
qos trust dscp
qos dbl
qos map dscp 24 25 26 27 28 29 30 31 to tx-queue 4
qos map dscp 32 33 34 35 36 37 38 39 to tx-queue 4
qos map cos 3 to dscp 26
qos map cos 5 to dscp 46
qos
policy-map autoqos-voip-policy
class class-default
dbl
3800
class-map match-all L3-to-L2_VoIP-RTP
match ip dscp ef
class-map match-all L3-to-L2_VOIP-Cntrl
match ip dscp af31
match ip dscp cs3
policy-map Voice_wan
class L3-to-L2_VoIP-RTP
priority 450
class L3-to-L2_VOIP-Cntrl
bandwidth 128
class class-default
fair-queue
lgijssel
Level 9
Level 9
First of all, a few assumptions that I cannot confirm from the post:
1: The 3800 router connects to your MPLS WAN?
2: The policy map as shown has been applied outbound on the 3800.
You could have an issue with trust on your LAN. In a cisco network you will need to trust QoS traffic on incoming interfaces and also on the trunks within the LAN. If this has been configured incorrectly, there will be no marked packets on the LAN. That implies that you will not see any on the WAN link either.
Keywords:
mls qos trust device cisco-phone on interfaces
mls qos trust cos on trunks
Also, make sure you have a voice vlan configured which has not the same vlanID as the native vlan.
regards,
Leo
