QOS Burst Rates
jamieparr
Hi all,
I have been working on our companies QOS policies for the best part of a week. I think I have everything present and correct in terms of a base policy.
We have a few links that require some policing, I am having some trouble with the burst rates; I think I am on the right track, however I am worried I may not be.
If I want to police a specific class and we are limiting the rate to 10000000 bits per second, the equation below doesn't make much sense to me:
normal burst = configured rate * (1 byte)/(8 bits) * 1.5 seconds
Do I take my configured rate of 10000000 multiply by 8000(1 byte) then divide by 8(8 bits) and multiply by 1.5? Giving me 384000000?
This to me makes no sense, am I reading the equation wrong?
Thanks in advance
Lei Tian
The equation is bc=cir/8 * 1.5. On your case, cir=10Mbit/s, so the bc=15Mbit or 1875Kbytes. You might want lower the time interval, 1.5 second seems too hight.
Please rate if it helps.
Lei Tian
Thanks Lei Tian,
The equation is a lot simpler than I thought. I am using 1.5 seconds as Cisco recommends this as the RTT. Is this not the case? Is there a method for determining RTT?
Jamie
Can anyone help with the RTT? I cannot find any Cisco documentation on calculating this.
Hi Jamie,
Sorry, I didn't see you asked another question. The RTR or TC is determined based on how bursty will you tolerate this type of traffic. A cir 10M with 1.5 second as the TC would allow temporary burst to 100Mb/s. I would not recommend use 1.5 second to calculate the BC, unless you know this type of traffic is very bursty by nature.
A rule of thumb is to use the platform default value, or use 200 ms if you have to configure the bc.
Please rate help posts.
Lei Tian
