QOS Conversion in IOS XE
NETAD
Level 4
Level 4
Hello, can you assist me in converting this QoS config to a compatible IOS XE config. Thank you very much.
there is no 1 to 1 conversion. Since you are using EtherChannel interfaces, you cannot use auto qos either.
Below is the converted auto qos output for 'trust dscp', which you can enter manually and apply the service-policy outbound on your interfaces:
class-map match-any PRIORITY_QUEUE_CLASS
match dscp cs4 cs5 ef
match cos 5
class-map match-any CONTROL_MGMT_QUEUE_CLASS
match dscp cs3 cs6 cs7
match cos 3
class-map match-any MULTIMEDIA_CONF_QUEUE_CLASS
match dscp af41 af42 af43
match cos 4
class-map match-any TRANS_DATA_QUEUE_CLASS
match dscp af21 af22 af23
match cos 2
class-map match-any BULK_DATA_QUEUE_CLASS
match dscp af11 af12 af13
match cos 1
class-map match-any SCAVENGER_QUEUE_CLASS
match dscp cs1
class-map match-any MULTIMEDIA_STREAM_QUEUE_CLASS
match dscp af31 af32 af33
policy-map OUTPUT_POLICY
class PRIORITY_QUEUE_CLASS
priority level 1 percent 30
class CONTROL_MGMT_QUEUE_CLASS
bandwidth remaining percent 10
queue-limit dscp cs2 percent 80
queue-limit dscp cs3 percent 90
queue-limit dscp cs6 percent 100
queue-limit dscp cs7 percent 100
queue-buffers ratio 10
class MULTIMEDIA_CONF_QUEUE_CLASS
class TRANS_DATA_QUEUE_CLASS
class BULK_DATA_QUEUE_CLASS
bandwidth remaining percent 4
class SCAVENGER_QUEUE_CLASS
class MULTIMEDIA_STREAM_QUEUE_CLASS
class class-default
bandwidth remaining percent 25
queue-buffers ratio 25
Can u pls help me to convert the below qos configuration for 9500 switches.
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 70 30
mls qos srr-queue input threshold 1 80 90
mls qos srr-queue input priority-queue 2 bandwidth 30
mls qos srr-queue input cos-map queue 1 threshold 2 3
mls qos srr-queue input cos-map queue 1 threshold 3 6 7
mls qos srr-queue input cos-map queue 2 threshold 1 4
mls qos srr-queue input dscp-map queue 1 threshold 2 24
mls qos srr-queue input dscp-map queue 1 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue input dscp-map queue 1 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue input dscp-map queue 2 threshold 3 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
