QoS - CoS 1812
d.rocco
Hi all,
i need to setup a 1812 with the following configuration:
- fastethernet 1 e 2 trunk with vlan 10,20,30,40
- fastethernet 3 with vlan 10 in access mode and Priority 3
- fastethernet 4 with vlan 20 in access mode and priority 4
- fastethernet 5 with vlan 30 in access mode and Priority 5
- fastethernet 6 with vlan 40 in access mode and priority 6
I didn't find any info for configure QoS on Cisco1812.
Is this possible?
Thanks in advanced
d.rocco
I found how to:
put the following command under the interface:
"switchport priority default 3"
interface FastEthernet2
end
router#sh inter fast 2 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: Disabled
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: ALL
Trunking VLANs Active: none
Protected: false
Priority for untagged frames: 3
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
router#
Diego
