Qos does not work on 2960S
MisterTof
i'm currenlty configuring Qos on 2960S platform (IOS 15.0(2)SE11, here is my configuration :
Policy-map :
WS-C2960S-48LPS-L#sh policy-map
  Policy Map PM_MARKING-POLICY
    Class CM_REALTIME-DATA
      set dscp ef
    Class CM_MULTIMEDIA-CONF-DATA
      set dscp af41
    Class CM_SIGNALING-CONTROL-DATA
      set dscp cs3
    Class CM_TRANSACTIONAL-DATA
      set dscp af21
    Class CM_BULK-DATA
      set dscp af11
    Class CM_SCAVENGER-DATA
      set dscp cs1
Class-map :
WS-C2960S-48LPS-L#sh class-map
Class Map match-all CM_TRANSACTIONAL-DATA (id 4)
   Match none
Class Map match-any class-default (id 0)
   Match any
Class Map match-all CM_SCAVENGER-DATA (id 6)
   Match none
Class Map match-all CM_MULTIMEDIA-CONF-DATA (id 2)
   Match none
Class Map match-all CM_SIGNALING-CONTROL-DATA (id 3)
   Match none
Class Map match-all CM_REALTIME-DATA (id 1)
   Match none
Class Map match-all CM_BULK-DATA (id 5)
   Match access-group name ACL_BULK-DATA
Access-list :
WS-C2960S-48LPS-L#sh ip access-lists ACL_BULK-DATA
Extended IP access list ACL_BULK-DATA
    10 permit tcp any any eq 8080
Service Policy applied to Gi1/0/1 :
interface GigabitEthernet1/0/1
description Telephone / Poste de travail
switchport access vlan 123
switchport mode access
switchport voice vlan 456
load-interval 60
power inline consumption 7000
power inline police
speed auto 1000
duplex full
srr-queue bandwidth share 1 30 35 5
priority-queue out
no snmp trap link-status
snmp ifindex persist
mls qos trust dscp
no mdix auto
storm-control broadcast level 10.00
storm-control multicast level 10.00
no cdp enable
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input PM_MARKING-POLICY
Global qos commands :
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 40 46
mls qos srr-queue output dscp-map queue 2 threshold 1 16 18 20 22 26 28 30 34
mls qos srr-queue output dscp-map queue 2 threshold 1 36 38
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 56
mls qos srr-queue output dscp-map queue 3 threshold 3 0
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 100 100
mls qos queue-set output 1 threshold 2 80 90 100 400
mls qos queue-set output 1 threshold 3 100 100 100 100
mls qos queue-set output 1 threshold 4 60 100 100 400
mls qos queue-set output 1 buffers 15 30 35 20
mls qos
Looking at the qos statisctics for the port gi1/0/1 I noticed that for web browsing (proxy port 8080) no packets appear in dscp 10 (AF11) in the outgoing dscp statistics. DSCP field should be rewrite to AF11 instead of DSCP 0 (for web browsing) because of Class-map CM_BULK-DATA & ip access-list ACL_BULK-DATA. Right or wrong ?
WS-C2960S-48LPS-L#sh mls qos int gi1/0/1 statistics
GigabitEthernet1/0/1 (All statistics are in packets)
  dscp: incoming
  0 -  4 :       34508            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0          269            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :      164343            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :       35012            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  0 -  4 :      252757            0            0            0            0
  5 -  7 :           0            0         2522
  output queues enqueued:
queue:    threshold1   threshold2   threshold3
queue 0:           0           0           0
queue 1:      128272        7224        2523
queue 2:           0           0      117350
queue 3:           0           0           0
  output queues dropped:
queue 0:           0           0           0
queue 1:           0           0           0
queue 2:           0           0           0
queue 3:           0           0           0
Policer: Inprofile:            0 OutofProfile:            0
I don't understand why. What is my mistake ? your help would be greatly appreciated. Thank you.
Christophe.
try and remove the 'mls qos trust dscp' from the interface...
--> Classification using a port trust state (for example, mls qos trust [cos | dscp | ip-precedence] and a policy map (for example, service-policy input policy-map-name) are mutually exclusive. The last one configured overwrites the previous configuration.
Hello Georg,
Thank you for your response. I tried your solution but it still doesn't work. Any other idea ?
Because service-policy is applied to input, should i have to look at dscp incoming rather than dscp outgoing ? I tried to change the direction of my acl but without success.
looking at the output you posted earlier, it looks like everything outgoing gets reset to dscp 0...
Can you post the full config of your switch ?
Hello Georg,
Yes I agree, all traffic reset do dscp 0. Since the last post I made some changes :
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
On the uplinks I added :
mls qos trust dscp
priority queue-out
Please found attached full config of the switch. Thank you very much for your help.
