QoS explanation in CIsco 3750 switch
george85
Hello guys,
I am trying to understand in 3750 switch how will behave with the below QoS configuration?
The below configuration is for input marked traffic that is coming from a device (host) with the appropriate dscp priotiry in to the switch.
For queue 1 how can distinguish in what threshold the packet will drop ? I have lost the concept i guess.
mls qos srr-queue input threshold 1 80 90
mls qos srr-queue input dscp-map queue 1 threshold 1 40 41 42 43 44 45 47
mls qos srr-queue input dscp-map queue 1 threshold 2 18 36
mls qos srr-queue input dscp-map queue 1 threshold 3 24 34
Also in Interface
interface FastEthernet1/0/x
srr-queue bandwidth share 10 40 20 30
srr-queue bandwidth shape 10 0 0 0
The switch has more configuration but for out traffic. Probably ill open a new thread for that.
BR
George
Joseph W. Doherty
"For queue 1 how can distinguish in what threshold the packet will drop ?"
First you determine which threshold (WTD1, WTD2 or queue full limit) the packet's ToS will use.
So, for example:
DSCP values of 18 or 36 will use the WTD2 setting.
Then the you need to see what the WTD2 (percentage) setting is.
BTW, generally you very, very rarely need to configure a 3750s ingress queues (from their defaults).
