QOS for voice
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-25-2013 09:23 PM - edited 03-07-2019 03:41 PM
Hi.
Why do I see voice traffic on one router and not on another:
Class-map: VOICE (match-all)
0 packets, 0 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: dscp ef (46)
Priority: 25% (9900 kbps), burst bytes 247500, b/w exceed drops: 0
8816096 packets, 1917880834 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: dscp ef (46)
It's the same service-policy on both routers.
regards
bjornarb
- Labels:
LAN Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-25-2013 10:09 PM
Can you provide more details, configuration? Show commands as well
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-25-2013 10:21 PM
Hi.
We assume that the voice traffic is marked at source.
Configuration:
class-map match-any BUSINESS
match access-group name MARK-BUSINESS
class-map match-all SHAPING
match any
class-map match-all VOICE
match dscp ef
policy-map QOS
class VOICE
priority percent 25
set dscp ef
class BUSINESS
bandwidth remaining percent 70
set dscp af31
class class-default
fair-queue
set dscp default
policy-map QOS_VRF_BRUKER
class SHAPING
shape average percent 100
bandwidth percent 99
service-policy QOS
interface GigabitEthernet0/1
service-policy output QOS_VRF_BRUKER
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-25-2013 10:29 PM
bjornarb
few comments here:
- The policy-map on the second router it looks it is not configured correctly, I dont see the priority in there
- Why do re mark the packet in your policy if it is already marked? no need for the command "set dscp ef"
- clear the counters and change the load-interval to 30 seconds on both switches, run voice traffic or use ping command with extended option and set the TOS to 184, and provide the show policy-map from both routers. I see the rate in both routers is zero, lets verify there are marked packet with this dscp
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-25-2013 10:46 PM
Hi again.
We removed the re-marking. Pinged with tos 184, but still no counters:
0 packets, 0 bytes
Match: dscp ef (46)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-25-2013 10:48 PM
Can you provide the complete output?
is the traffic matching the class-default?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-25-2013 10:53 PM
#sh policy-map interface gigabitEthernet 0/1
GigabitEthernet0/1
Service-policy output: QOS_VRF_BRUKER
Class-map: SHAPING (match-all)
396310 packets, 50532155 bytes
30 second offered rate 751000 bps, drop rate 0 bps
Match: any
Queueing
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 396310/50538173
shape (average) cir 40000000, bc 400000, be 400000
target shape rate 40000000
bandwidth 99% (39600 kbps)
Service-policy : QOS
queue stats for all priority classes:
(pkts output/bytes output) 0/0
0 packets, 0 bytes
Match: dscp ef (46)
Class-map: BUSINESS (match-any)
396219 packets, 50522352 bytes
Match: access-group name MARK-BUSINESS
30 second rate 751000 bps
Queueing
(pkts output/bytes output) 396219/50528370
bandwidth remaining 70% (20790 kbps)
QoS Set
dscp af31
Packets marked 396219
Class-map: class-default (match-any)
91 packets, 9803 bytes
Match: any
Queueing
(queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
(pkts output/bytes output) 91/9803
Fair-queue: per-flow queue limit 16
QoS Set
dscp default
Packets marked 0
0 packets, 0 bytes
Match: any
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-25-2013 11:29 PM
Here is the output after 20 ping with TOS 184.
20 packets, 2360 bytes
5 minute offered rate 1000 bps, drop rate 0 bps
Match: dscp ef (46)
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 25 (%)
Bandwidth 10000 (kbps) Burst 250000 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-26-2013 01:54 AM
The problem was that if you have auto qos on trunk ports it will remove the marking if you do not have qos on access ports.
