QOS in Cisco 6500
smartboy2255
Hi all,
   I want to prioritise my application traffic in my LAN.How can I achieve the same with L2 QOS.
Arun
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
L2 VLAN tagging supports CoS which many L2 manageable switches can use to treat some application traffic differently from other application traffic.  You would need to correctly tag your traffic and configure your switches to process it differently.
You should also insure packets have the L3 ToS byte tagged too.  You can often use the L3 ToS byte to set L2 CoS, as needed, and sometimes you can directly treat traffic differently on some "enhanced" L2 switches using it.
