QoS on 2950-EMI again
wmmak
Dear All,
I find the the example below of configuring standard QoS on intelligent traffic
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12120ea2/2950scg/swqos.htm#wp1026720
May I know can I apply it on egress interface (service-policy output xxx), or it is the limitation on 2950 that only apply on ingress interface?
Thanks a lot
mak
Prashanth Krishnappa
You can only police ingress traffic on a CAT2950.
Cat2950(config-if)#service-policy ?
input Assign policy-map to the input of an interface
You can workaround by policing at ingress on the uplink as well((which is equivalent to policing egress on all interfaces).
