QOS on Cisco 1841
mnguyen
I need to implement QOS to give the highest traffic priority for a particular IP address or application. Could somebody send me sample CLI code to implement this on a cisco 1841 router?
Mark
Mahesh Gohil
Level 7
Level 7
Hello Marc,
Please find
ip access-list extended 101
permit ip any
class-map PRIORITY
match ip address 101
policy-map COS-OUT
class PRIORITY
priority
class class-default
bandwidth
with priority you can define percentage/remaining-percentage also
and apply in output direction towards wan interface
int
service-policy output COS-OUT
Hope this helps
Mahesh
Thanks Mahesh.  This is what I am looking for.  Could you also send me same code to implement QOS for a particular application?  I need my SQL traffic port 1433 to have the highest priority.
Mark
Hello marc,
Router(config)#access-list 102 permit tcp any any  eq ?
  <0-65535>    Port number
Mahesh
