QoS on MSFC VLAN Interface
sasaadamovic
Hi All,
Any help would be greatly appreciated.
I am trying to apply some QoS setting s on VLAN interface on MSFC (Hybrid 6509). Here is the config:
class-map match-any VoiceClass
description voice traffic
match access-group 140
match ip dscp 46
class-map match-any Business1Class
description video
match access-group 141
match ip dscp 26
class-map match-any Business2Class
description business apps
match access-group 142
match ip dscp 18
class-map match-any Business3Class
description not FT traffic
match access-group 143
policy-map LondonPolicy
description QoS Policy for London
class VoiceClass
priority percent 5
set ip dscp 46
class Business1Class
priority percent 10
set ip dscp 26
class Business2Class
priority percent 15
set ip dscp 18
class Business3Class
priority percent 45
class class-default
fair-queue
policy-map LondonPolicyParent
description shaping for Virtual interface
class class-default
shape average 100000000 400000 400000
service-policy LondonPolicy
access-list 140 permit ip host a.b.c.d host a.b.c.d
access-list 141 permit ip host a.b.c.d host a.b.c.d
access-list 142 permit tcp any any eq XXX
access-list 142 permit tcp any any eq YYY
access-list 142 permit tcp any any eq 8000
access-list 143 deny ip any host a.b.c.d
access-list 143 deny tcp any any eq XXX
access-list 143 deny tcp any any eq YYY
To apply the policy I use following command:
interface VLAN 507
service-policy output LondonPolicyParent
However, when I apply this to VLAN interface I do not see any error, but policy is simply not accepted. Command "show policy-map interface vlan 507" does not return anything.
I previously had similar QoS policy, but without shaper (parent) and without percent statements, used just to mark packets. However I need to enforce QoS as we are experiencing occasional high utilisation due to file transfer (FT) apps. I can apply “LondonPolicy”, without shaper (parent), but I need a shaper. There is a single 100Meg port in this VLAN connected to LAN Extension circuit so I want to throttle traffic at 100Meg and introduce some QoS.
Any idea why this does not work?
13 Replies 13
Edison Ortiz
Shaping isn't supported on regular line cards in the 6500.
You need a FlexWAN or SIP/SPA module for extensive QoS support.
You are only allowed to trust/mark or police packets.
HTH,
__
Edison.
Hi Edison.
Thanks for you update.
Can you please, clarify something for me. When you say "You are only allowed to trust/mark or police packets." do tou mean that shaping is not allowed or that no enforcmen of policy would work even if we remove shaper (parenth) policy and rewrite policy to be based on 1Gb interface bw?
Sasa
Sasa,
I meant Shaping is not a supported feature on 6500 line cards as they don't have enough hardware buffers to delay the traffic. A dedicated WAN module such as FlexWAN or SIP/SPA would provide such services and that's the reason that command is available in the 6500 CLI.
I highly recommend to start reading the 6500 QoS at the following URL:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/qos.html
It will help you understand the requirements and caveats on the configuration.
Since you are using Hybrid, you need to understand the CatOS portion as well. The following URL provides the needed information:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/7.x/configuration/guide/qos.html
You also mentioned you are working with TAC. I suggest you continue doing so and please follow their guidelines.
HTH,
__
Edison.
Hi Edison,
Thanks for your help.
Will read the documents you suggested.
Sasa
Joseph W. Doherty
You're going to have a 100 Mbps Ethernet port but you need to shape at 100 Mbps?
As Edison notes, 6500 "LAN" ports are often QoS feature limited. Besides his suggestion to use a 6500 "WAN" card, you might also consider placing another device in-line to provide additional outbound QoS. For example, the 8 port 2960 switch offers 4 FIFO queues per port and supports port bandwidth "shaping".
Thanks James,
Unfortunately, this solution with additional switch would not help me. We have 6509 with 100Mb ports connected to LAN extension cirtcuit (behaves as 100Mb Ethernet) to remote office and we see packet drops when that 6509 port is overutilised, which is going to happen even with QoS implemented on down stream switch. Actually, thinking about this, solution would be to put inline switch, but connected to 6509 with Gyg port and inforce policy on 100 Mb port connected to LES circuit.
Thanks for suggestion,
Sasa
Yes, you're correct, but that's why I questioned why you need shaping if you have a 100 Mbps port working with a 100 Mbps LES. In that sitution, you shouldn't need to shape, just use the hardware queues supported by the 6500 LAN port.
If you did need to shape, such as your example gig to 100 Mbps, or 100 Mbps to some fraction of 100 Mbps, that's where the inline switch could be of benefit.
Regardless of bandwidth, if a circuit is oversubscribed, it's quite normal some packets will be dropped. With QoS, you can prioritize some traffic so it's not delayed by the overall link congestion and/or better manage what packets are dropped.
Thanks Joseph,
How do I configure hardware queues on 6509, when my priorities are based on either destination IP address or destination TCP/UDP ports and 6509 switch is running CatOS and cirrect me if I am wrong, can not deal with traffic above layer 2. Do you suggest that I should upgrade my hybrade (atOS on the switch and IOS on MSFC) to native IOS and then deal with it that way.
Thanks for any updates.
Sasa
Sasa, good question.
I haven't worked with a 6500 running hybrid mode in several years. Even with native mode, I rarely work with 6500 LAN QoS, since on the LAN, often avoid the need for QoS, instead provide sufficient bandwidth.
I'm pressed for time at the moment, so I'm unable to dig into the 6500 QoS docs, but would expect there may be some way to use or mark DSCP or CoS upon 6500 ingress, and have egress DSCP or CoS markings map to hardware queues. Your multiple hardware queues might also need to be configured (e.g. bandwidth allocations, drop limits).
If you're still have difficulty, and no one else is able to help, I should have time this evening to examine the docs.
Hi Joseph,
Thanks for your help. It is very nice of you to offer this, but it would be to much of me to ask you to spend your time digging configurations and examples for me. I would press our cisco support to help with this (I already have a ticekt open).
However, I would appreciate if yu can quickly clarify if I correctly understood what you are saying.
My understanding of your suggestion is that I should:
1) mark packets on my MSFC
2) Configure switch to trust this marking
3) On the switch translate dscp in CoS marking
4) Configure switch to enforce QoS on specific port based on that marking by maping CoS to specific queues on port.
Just short explenation/clarification on this would be great help.
Sasa
Sasa, yes that's mostly what I had in mind. Your running in hybrid mode, might impact the situation.
Also, you might not need to map down to CoS markings. L3 switches often seem to be able to understand the DSCP markings. But, without checking docs, I'm unsure this is so on the 6500.
Thanks Joseph,
I do understand what are my options.
I will follow this up with our cisco support and also will study the documentation.
Sasa
Sasa, well without digging into the documentation, and knowing your exact hardware and IOS (and CATOS), unsure what your options really are. However, again, I'm assuming you should be able to classify (somehow) traffic upon 6500 ingress, and based on this classification, direct traffic to the egress interface queues. I would expect hybrid mode might be a bit more complex to configure, although generally it's feature comparable with native mode. I don't expect, without using a "WAN" type card, that you'll be able to easily configure what you want using MQC.
