QoS on Nexus 3000
dukenuk96
Level 3
Level 3
Hi all!
I'm trying to resolve the following task - we have a Nexus 3000 switch which acts as transit L2 switch between our routers, several ISPs and private WAN links. I want to preserve bandwith for routing and management protocols to prevent user-generated traffic from affecting routing adjacencies and management applications (RDP, SSH, etc..)
I have read configuration guide, several articles and watched Cisco Live videos about QoS implementation on Nexus switches. Then my brain yielded the following configuration:
!!! ACLs to catch specific traffic patterns
ip access-list AL-Routing-Protocols
10 remark # BFD Echo #
20 permit udp any any eq 3785
30 permit udp any eq 3785 any
40 permit tcp any any eq 3785
50 permit tcp any eq 3785 any
60 remark # BFD Control #
70 permit udp any any eq 3784
80 permit udp any eq 3784 any
90 permit tcp any any eq 3784
100 permit tcp any eq 3784 any
110 remark # BFD Multihop Control
120 permit udp any any eq 4784
130 permit udp any eq 4784 any
140 permit tcp any any eq 4784
150 permit tcp any eq 4784 any
160 permit ospf any any
170 permit tcp any any eq bgp
180 permit tcp any eq bgp any
ip access-list AL-Management-Protocols
10 permit tcp any any eq 22
20 permit tcp any eq 22 any
30 permit tcp any any eq 3389
40 permit tcp any eq 3389 any
50 permit udp any any eq 3389
60 permit udp any eq 3389 any
70 permit tcp any any eq 23
80 permit tcp any eq 23 any
ip access-list AL-Our-AS-Addrs-Only
10 permit ip 169.254.0.0/16 169.254.0.0/16
ip access-list AL-any-IP-Traffic
10 permit ip any any
class-map type qos match-any CM-QoS-Routing-Protocols
match access-group name AL-Routing-Protocols
class-map type qos match-any CM-QoS-Management-Protocols
match access-group name AL-Management-Protocols
class-map type qos match-any CM-QoS-Our-AS-Traffic-Only
match access-group name AL-Our-AS-Addrs-Only
policy-map type qos PM-QoS-Edge-Class-and-Internal-pre-Mark
class CM-QoS-Routing-Protocols
set qos-group 5
class CM-QoS-Management-Protocols
set qos-group 4
class CM-QoS-Our-AS-Traffic-Only
set qos-group 3
class-map type queuing CM-Queuing-Routing-Protocols
match qos-group 5
class-map type queuing CM-Queuing-Management-Protocols
match qos-group 4
class-map type queuing CM-Queuing-Our-AS-Traffic-Only
match qos-group 3
policy-map type queuing PM-Queuing-Internet-Edge
class type queuing CM-Queuing-Routing-Protocols
bandwidth percent 5
priority
class type queuing CM-Queuing-Management-Protocols
bandwidth percent 20
class type queuing CM-Queuing-Our-AS-Traffic-Only
bandwidth percent 30
class type queuing class-default
interface e1/51
service-policy type qos input PM-QoS-Edge-Class-and-Internal-pre-Mark
service-policy type queuing output PM-Queuing-Internet-Edge
Then I try to verify what's happening on the interface:
SD2-5-8-22-L2SW-155(config)# sh queuing interface e1/51
Ethernet1/51 queuing information:
qos-group sched-type oper-bandwidth
0 WRR 30
qos-group 0
HW MTU: 1500 (1500 configured)
drop-type: drop, xon: 0, xoff: 0
Statistics:
Ucast pkts sent over the port : 66122156488
Ucast bytes sent over the port : 42691127066217
Mcast pkts sent over the port : 46358
Mcast bytes sent over the port : 3038776
Ucast pkts dropped : 6363974
Ucast bytes dropped : 9145820663
Mcast pkts dropped : 0
Mcast bytes dropped : 0
Pkts dropped by RX thresholds : 0
Bytes dropped by RX thresholds : 0
SD2-5-8-22-L2SW-155(config)# sh policy-map interface e1/51
Global statistics status : enabled
NOTE: Type qos policy-map configured on VLAN will take precedence
over system-qos policy-map for traffic on the VLAN
Ethernet1/51
Service-policy (qos) input: PM-QoS-Edge-Class-and-Internal-pre-Mark
policy statistics status: enabled
Class-map (qos): CM-QoS-Routing-Protocols (match-any)
Match: access-group AL-Routing-Protocols
set qos-group 5
Class-map (qos): CM-QoS-Management-Protocols (match-any)
Match: access-group AL-Management-Protocols
set qos-group 4
Class-map (qos): CM-QoS-Our-AS-Traffic-Only (match-any)
Match: access-group AL-Our-AS-Addrs-Only
set qos-group 3
Class-map (qos): class-default (match-any)
Match: any
set qos-group 0
Service-policy (queuing) input: default-in-policy
Class-map (queuing): class-default (match-any)
Match: qos-group 0
bandwidth percent 100
Service-policy (queuing) output: PM-Queuing-Internet-Edge
Class-map (queuing): CM-Queuing-Routing-Protocols (match-any)
Match: qos-group 5
bandwidth percent 5
priority
queue dropped pkts : 0 current depth pkts: 0
queue dropped bytes : 0 current depth bytes: 0
queue transmit pkts: 0 queue transmit bytes: 0
queue max depth pkts: 0 queue max depth bytes: 0
Class-map (queuing): CM-Queuing-Management-Protocols (match-any)
Match: qos-group 4
Class-map (queuing): CM-Queuing-Our-AS-Traffic-Only (match-any)
Match: qos-group 3
Match: qos-group 0
queue dropped pkts : 6363974 current depth pkts: 0
queue dropped bytes : 9145820663 current depth bytes: 0
queue transmit pkts: 66122180569 queue transmit bytes: 42691145285775
Strange things on the interface - qos-group 0 is the only one active with oper-bandwidth of 30, so part of the configuration is applied. Also I do see that policy-map for marking (type qos PM-QoS-Edge-Class-and-Internal-pre-Mark) and for queuing (type queuing PM-Queuing-Internet-Edge) are applied, but there is no traffic in them. Moreover, there are drops in default queue, but total traffic is about 150mbps on the interface and if I understand queuing correctly, it should drop packets only in case of congestion when there is traffic in other or priority queues competing for remaining bandwidth.
Please tell me what am I doing wrong? I know there are more objects like system qos and network-qos, but from configuration guide I cannot get solid understanding why and how do I need to configure them if I want to configure classification, marking and bandwidth management only on a few interfaces and not on the whole switch.
Thanks.
Robert Hoeger
first of all it seems that qos-group 5-7 is already defined and in use for "internal usage" (you use qos-group 5):
"By default, queues 6 and 7 are reserved for control plane traffic and queue 5 for SPAN traffic. So you
can configure four classes along with the default class."
=> default class is qos-group 0, so only qos-group 1-4 can be configured!
You cannot see any statistics because you have to "activate" the qos-groups "internally" - see Cisco Live Breakout Session 2930 (London):
"The network-qos policy instantiates the QoS-Groups when applied to the system policy. This enables the QoS-Groups and interface statistics collection per QoS-Group."
Example:
Define the Class-Maps and match the QoS-Group values
N3K-1(config)# class-map type network-qos qos-group-1
N3K-1(config-cmap-nq)# match qos-group 1
N3K-1(config-cmap-nq)# class-map type network-qos qos-group-2
N3K-1(config-cmap-nq)# match qos-group 2
N3K-1(config-cmap-nq)# class-map type network-qos qos-group-3
N3K-1(config-cmap-nq)# match qos-group 3
Define the Policy-Map and match the Class-Maps previously defined
N3K-1(config)# policy-map type network-qos qos-groups
N3K-1(config-pmap-nq)# class type network-qos qos-group-1
N3K-1(config-pmap-nq)# class type network-qos qos-group-2
N3K-1(config-pmap-nq)# class type network-qos qos-group-3
Apply the Policy-Map to the system (this activated the groups)
N3K-1(config)# system qos
N3K-1(config-sys-qos)# service-policy type network-qos qos-groups
Best regards
Robert
