QOS on nexus 9000
sateeshk10
I need quick configuration on qos marking i.e whatever the traffic is coming in  interface(any traffic) should mark with high prioty.
please crorrect me:
Ip access-list test permit any any
class-map match-any test-class
 match access-group name test
policy-map test-policy
 class test-class
  set dscp ???
int e0
service-policy input test-policy
Kumar
Francesco Molino
First of all, you can define the priority level from 1 to 3 under the policy-map. 1 is top priority.
If you want to mark all traffic with a specific dscp and set as high priority, you can use your config or even use the class-default.
However, setting all traffic as high priority doesn't make any sense because if some day you have a congestion, prioritizing all traffic won't be the solution.
Can you maybe explain a bit what you want to achieve?
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco
Thanks and Could you please give me the configuration.
Sateesh k
What type of configuration you want?
What do you want to achieve exactly?
Francesco
