QOS Policy Map Help.
fernandes.steve
Community Member
Hi Guys,
To help clarify, I have attached a visual document of what I am trying to accomplish:
Problem: 100 MEG MPLS is getting saturated by internet traffic request and server files request. Site B suffers packet loss for phones. Student VLAN uses all available bandwidth.
Solution: I want to police student bandwidth coming into site B, before it traverses past the MPLS. I.E drop the traffic going from site A to site B, at SITE A.
Currently I have applied the policy map, I have posted below to INTERFACE GI2/0/2 AT SITE A.
However I think because I have specified it as an input policy, it is unable to match any of the statements, because at the port level, the MPLS physically plugs into the switch.
I could apply my above policy map Interface GI2/0/2 at SITE B, however if I do that traffic is still saturating the MPLS network as its already traversing over it, and at which point its pointless to drop the traffic once it arrive at its destination at site B.
I am not sure how I can apply my policy.
I was trying to read up on QOS based on SVI, but I do not understand the difference quite well and I am not sure if it would apply in my case.
I have pasted my policy map code below for quick reference:
ip access-list extended ACL_DB_QOS
 permit tcp any any eq 1433
 permit udp any any eq 1434
exit
ip access-list extended ACL_JRLAB_QOS
 permit ip any 10.0.0.0 0.0.1.255
 permit ip any 10.6.20.0 0.0.1.255
exit
class-map match-all CLASS_VOICE_EF_QOS
 match ip dscp ef
exit
class-map match-all CLASS_VOICE_SIGNAL_QOS
 match ip dscp cs3
exit
class-map match-all CLASS_DB_APP_QOS
 match access-group name ACL_DB_QOS
exit
class-map match-all CLASS_JRLAB_QOS
 match access-group name ACL_JRLAB_QOS
exit
policy-map TO-JR-QOS
 class CLASS_VOICE_EF_QOS
     set dscp ef
 exit
 class CLASS_VOICE_SIGNAL_QOS
     set dscp cs3
 exit
 class CLASS_DB_APP_QOS
     set dscp af21
 exit
 class CLASS_JRLAB_QOS
     police 51200000 524288 exceed-action policed-dscp-transmit
 class class-default
     set dscp 0
 exit
exit
Hello
I cannot see your diagram but for L2 qos
you can police on your lan
mls qos
policy-map tst
class class-default
police xxxxxx bc=cir/32 conform action transmit exceed action drop
lan facing intercomnect (svi)
service policy input tst
trunk interface
mls qos vlan-based
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
Hi PDriver,
I am not sure I understand a few things.
I did attach a general physical connection diagram of the network.
There are basically two layer 3 switches (Both doing routing on each end) that are connected to each other through an MPLS cloud.
Can you please explain the LAN FACING interconnect SVI? Is that the physical switch port. That switchport that the MPLS connects to to the core is only an access layer port in VLAN 1.
