QoS problem on 3560
franklaszlo
I wanted to classify smtp traffic on one of the ingress port of a 3560 switch, but it seems that classification does not work.
Here is the simple config related to qos.
mls qos
class-map match-all SMTPTraffic
match access-group 100
policy-map SMTPPolicy
class SMTPTraffic
set dscp af11
interface GigabitEthernet0/7
switchport mode access
service-policy input SMTPPolicy
access-list 100 permit tcp any any eq smtp
All the ACL and the PolicyMap counters remain 0, and queuing statistics show all egress frame marked with dscp 0.
What am I missing ?
Thanks in advance,
Laszlo
10 Replies 10
mheusinger
Level 10
Level 10
is the ACL direction correct?
OR
access-list 100 permit tcp any eq smtp any
For testing purposes you could match on all IP traffic until you get the desired markings.
Also be aware, that all Catalyst ports are untrusted by default, i.e. the next Catalyst will remark everything to DSCP 0 if the (trunk) port is not configured to trust all incoming markings.
Regards, Martin
Hi Martin,
I guess yes, it is correct, but I also tried any combination, that is
any eq smtp any
any eq smtp any eq smtp
any any eq smtp
but the results are the same.
Laszlo
you wrote :
"Also be aware, that all Catalyst ports are untrusted by default, i.e. the next Catalyst will remark everything to DSCP 0 if the (trunk) port is not configured to trust all incoming markings. "
Well, regarding the bcmsn book, I do not have to trust the ingress frame when using policy map to explicitly set the dscp value. Is this not true ? The config guide also suggest this.
Laszlo
Hi Laszlo,
I just meant it might happen, that markings are implemented by the 3560 but the next switch remarks to 0 again. It depends on where you sniffer the traffic (which I would do, to rule out "simple" counter problems = IOS bug).
So your input policy seems ok.
Regards, Martin
Hi Martin,
I actually misunderstood you, both the classification and queuing should happen on tha same switch.
Anyway, if the policy seems correct what else do you think is missing ? All match counters show 0.
Pls look at this :
C3560#sh policy-map interface gi 0/7
GigabitEthernet0/7
Service-policy input: smtp_policy
Class-map: SMTPTraffic (match-all)
0 packets, 0 bytes
offered rate 0 bps, drop rate 0 bps
Match: access-group 100
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
rate 0 bps
C3560#sh access-lists
(text deleted)
Standard IP access list management_computers
10 permit 10.1.1.19 (34 matches)
20 permit 10.1.1.204 (28 matches)
Extended IP access list 100
10 permit tcp any eq smtp any
20 permit tcp any eq smtp any eq smtp
30 permit tcp any any eq smtp
Extended IP access list 101
(text deleted)
Thanks in advance,
Laszlo
just for testing use "permit ip any any" as the ACL.
Regards, Martin
this produces the same effect, no match, counters remain 0. However, there is a constatnt smtp flow through the interface.
Laszlo
I have the same problem.
Can you resolve it? Did you find the problem?
Thanks a lot.
no, half as I would expect. On this forum and also on others, some people told me that the "show policy map interface" command is obsolete and will always show zero counter values. I also found this in some cisco documents. However, I still do not know how to monitor then the classification process and I would really appreciate if someone could tell me .
Laszlo
now I have the solution for this problem :
1 : Under a Cisco bug ID it is documented as follows :
Problem:
In a CAT3550, show policy interface doesn't show statistics even
when traffic is flowing through the policy.
Workaround:
show mls qos interface [interface-
id] statistics should be used instead.
2 : ACL match is not incremented because QoS is implemented in hardware.
And the config actually works. You can see it if you check the particular egress interface for the classified traffic (not the port where classification takes place), by using the above mentioned command.
Laszlo
