QoS question
keith_chilek
device---3560---trunk---3560---device
If "device" is marking packets with a TOS of 184, is there a quick and easy QoS config I can put on the 3560s that will give priority to those packets?
Thanks!
Joseph W. Doherty
For "quick and easy", if the 3560 supports it, AutoQoS might. (NB: AutoQoS might also do much more that you don't want.)
Otherwise, you'll need provide a manual config. For just ToS 184 (DSCP EF), you would want to insure this value is trusted and it processed in the PQ on egress queues. You would also need to determine what you want to do with all your other traffic.
