qos switch 2960s problem
eddanilo2016
Frequent Visitor
Frequent Visitor
hi guys
I need your help I have the following configuration but the qos does not work for me
SW-Core(config)#ip access-list extended qos
SW-Core(config-ext-nacl)#permit ip any host 192.168.1.30
SW-Core(config-ext-nacl)#permit ip any host 192.168.210
SW-Core(config-ext-nacl)#permit ip any host 192.168.1.248
SW-Core(config)#class-map qos-services
SW-Core(config-cmap)#match access-group name qos
SW-Core(config)#policy-map politica-qos
SW-Core(config-pmap)#class qos-services
SW-Core(config-pmap-c)#set dscp af11
Here I apply the interface the policy
interface GigabitEthernet1/0/6
switchport access vlan 110
switchport mode access
spanning-tree portfast
service-policy input politica-qos
Here I verify that I am applying but when I make connections to those destinations it does not work for me
SW-Core#show policy-map interface gigabitEthernet 1/0/6
Service-policy input: politica-qos
Class-map: qos-services (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group name qos
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
5 minute rate 0 bps
thanks for your help
regards
edwin
eddanilo2016
Frequent Visitor
Frequent Visitor
hi guys
0 packets, 0 bytes
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
5 minute rate 0 bps
regards
edwin
