QOS: Unable to se Matches against ACL bound to Class-maps
Darshan Argekar
QOS: Unable to se Matches against ACL bound to Class-maps. We are initiating ping test with TOS 184 . We are seeing traffoic moviong vial EF class however we are not seeing matches against corresponding ACLs. Also unable to see any bug toolkit for this one. Request kind help in this regards. Thanks
Cisco ASR : 1002
12.2(33r)XNC
ping 3.3.3.3 source 2.2.2.2 TOS 184 ( repeat count 99 )
Class-map: ce_xx_xxxx  (match-any)
          99 packets, 11286 bytes                                                  <<<<< 99 Packet seen in the Policy and marked correctly
          5 minute offered rate 1000 bps, drop rate 0000 bps
          Match: class-map match-all ce_xx_xxxx2
            Match: class-map match-any ce_xx_xxxx1
              Match: access-group 184                                             <<<<< ACL asssociated with it.
            Match: not access-group 198
            Match: not access-group 197
          Match: access-group 189
          police:
              cir 14952000 bps, bc 20000 bytes, be 20000 bytes
            conformed 99 packets, 11286 bytes; actions:
              set-dscp-transmit ef                                              <<<<< 99 Packet seen in the Policy and marked correctly
            exceeded 0 packets, 0 bytes; actions:
              drop
            violated 0 packets, 0 bytes; actions:
              drop
            conformed 1000 bps, exceed 0000 bps, violate 0000 bps
          Priority: Strict, b/w exceed drops: 0
aa-wipyl-nbry1-lma-eu#sh ip access-l 184
Extended IP access list 184
    10 permit ip host 2.2.2.2 host 3.3.3.3
Jon Marshall
Darshan
The ASR is a hardware based router. Because of this you do not see hits on any packets that are hardware switched. This is also a common issue with Catalyst switches. So just because you do not see hits does not mean it is not working.
It's not just QOS acl's it's all acls ie. acls for filtering, PBR acls etc.
See this thread for more details -
https://supportforums.cisco.com/message/3401685
Jon
Jon Marshall
Darshan
Jon
